Roller Block sleeper
Old Mar 3, 2009 | 12:35 PM
ForceFedFun's Avatar
ForceFedFun
Default Roller Block sleeper
Hi,
i am going to put a 94 roller block into a 67. I am going to keep it carberated and i have just about all the parts sourced. I need some help with the distributor. I know that the roller block has steel cams and I need to get a distributor gear to match. After its all said and done i think that an 85 5.0 distributor will work since it has a steel cam as well. The question i have is how do I wire it up? Do I cot the pigtail off and then whire the red one to the coil and the black to ground? Also to note would be the no more points and a great sleeper look with the gt40 heads and painted dual plane edelbrock intake. Thanks for your time. Please PM if you have any info that could help or forcefedfun@yahoo.com
Old Mar 3, 2009 | 05:28 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
http://www.mustangsteve.com/conversion.html <---there you go buddy
GimpyHSHS
19
Dec 19, 2023 01:12 PM
mustangheaven
Jan 3, 2016 11:20 AM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
mustangheaven
Sep 29, 2015 11:00 AM
wraith777
Sep 28, 2015 10:49 AM
