ignition wiring issues help me help my friend
We are working on a 66 stang with a 302. Dura spark ignition with some kind of upgrade. (he said hei but that isn't right). it ran until he tried to change the ignition switch. He can't quite remember how it was before. He has a blackwire that can only go on the center pole. A yellow wire that we are pretty sure about. one red that goes to the coil aand one red that seems to go to the starter solenoid. The problem is that when we hook it up the way we think it should go it tries to start in the accessory position.
I had a dura spark II system in my car before. I ripped all of that out, and installed an HEI distributor. One wire from the ignition switch, and one to the tach. Easy, clean, done.
It's pretty close to the MC bar, but everything clears.
mungodrums
Oct 7, 2015 04:01 AM
