i could use a little help....
Old Jun 28, 2010 | 12:18 PM
prizefighterinferno's Avatar
prizefighterinferno
Default i could use a little help....
this is my first post on any mustang forum, so i hope i do it right. here goes....i have a 66 coupe. and i recently came across some pro comp parts(distributor, coil, and multi spark box). but the problem i'm having is that i can't find a diagram showing where the coil and spark box can mount. does anyone have any suggestions where i might find some help? or does anyone know where they can mount? thanks.
Old Jul 1, 2010 | 01:36 AM
beaujamesharrington's Avatar
beaujamesharrington
My coil has a bracket that mounts to the intake manifold on the passenger side. Really your coil should be semi close to your distributor.
As for your multi spark box, mine is mounted on the firewall right behind the engine. You can mount that anywhere under the hood if you prefer. But i would recommend on the firewall. It looks the best. No matter where you put it, it will function the same.
Old Jul 2, 2010 | 09:01 AM
GT350R Klone's Avatar
GT350R Klone
Yea, you can mount them where they look good to you and have space. Just keep them away from exhaust manifold.
Old Jul 3, 2010 | 01:53 AM
andrewmp6's Avatar
andrewmp6
The box you can put anywhere mines in my glove box.The coil from the factory was on the intake but you can mount it anywhere the coil wire will reach.
McZombie
Mar 8, 2008 02:01 AM
Brian76
Feb 24, 2008 06:13 PM
therobman7
May 19, 2007 02:49 PM
uvastang
Chop Shop
Feb 26, 2007 05:37 PM
aamilo
Feb 13, 2005 08:45 PM
