engine compartment paint
hello....i had a list of recommended colors to paint the:
springs
bolts
hinges
air cleaner
engine
valve covers
everything under the hood & trunk etc...
if you have this list or know where to find it, can you please direct me so i can find it again.
i appreciate your help.
mike
springs
bolts
hinges
air cleaner
engine
valve covers
mike
I found the list I was looking for...thought i would share it.
Mike
To Paint or Not to Paint
The following is a list of some Mustang parts that SHOULD NOT BE PAINTED. These parts should be removed from the car prior to painting, but if that is not possible, they should be carefully masked. These items were originally either natural finish metal, light phosphate coating, or cadmium plated finish. They may have rust on them which will need to be removed by using SOS pads, sand blasting, or redi-stripping. Once cleaned they may be coated with a clear lacquer(this is not permanent as rust will return after a couple of years), painted with a natural finish or cast iron paint, replaced or re-plated.
Underhood
Hood hinge (1964 & up)
Hood hinge spring (1965 & up)
Master brake cylinder
Gas pedal rod and linkage
Hood latch (hook part)
Hood latch stud (1965-6)
Hood catch bar (1967 & up)
Windshield washer nozzle
Steering gear box
Steering linkage
Emergency brake linkage
Brake and Gas lines
Alternator
Ball joints
Hood mounted turn light body (1967-70)
Fuel Pump
Fan spacer
Carburetor spacer
Brake junction block
Oil pressure sending unit
Power steering bracket (1967-8)
Alternator bracket
Generator bracket
Clutch linkage
Bell housing
Transmission
Shifter linkage
Windshield washer pump
Transmission cross member
Doors
Door latch striker plate
Trunk
Trunk latch mechanism Gas tank filler pipe
Trunk latch assembly
Trunk catch
Trunk lock extension bar
Trunk lock spring
Gas tank
Tail light body
Undercarriage
Licence plate light body
Drive shaft
Exhaust hangers
Rear spring shackles
Universal joint
Differential yokes
Mike
Underhood
Steering gear box
Steering linkage
Brake and Gas lines
Alternator
Ball joints
Fuel Pump
Fan spacer
Carburetor spacer
Alternator bracket
Generator bracket
Clutch linkage
Bell housing
Transmission
Shifter linkage
Doors
Trunk
Trunk catch
Trunk lock spring
Gas tank
Tail light body
Undercarriage
Drive shaft
Exhaust hangers
Universal joint
Differential yokes
