Performance
Old Sep 14, 2011 | 10:08 PM
ARobb 71's Avatar
ARobb 71
Default Performance
What is the best way to upgrade my 71 mustang with a 302 engine?
Old Sep 14, 2011 | 10:10 PM
lucasp's Avatar
lucasp
engine swap?
Old Sep 14, 2011 | 11:00 PM
ARobb 71's Avatar
ARobb 71
something that adds onto this engine, i was thinking 4 brrl carb, with a new intake manifold or something
Old Sep 15, 2011 | 12:55 AM
andrewmp6's Avatar
andrewmp6
Bolt ons can only get you so far if you want over 300hp plan for a full rebuild with upgrades.
Old Sep 15, 2011 | 07:55 AM
JMD's Avatar
JMD
How much do you want to spend?
IMO, the biggest bang for the buck for these engines is a good set of aftermarket heads and an intake..... Pricy up front, but they make all other mods worth much more...
Old Sep 15, 2011 | 03:02 PM
jlg2002's Avatar
jlg2002
I agree with JMD but you'd be surprised how much a set of headers and a dual exhaust will wake up an stock engine. the stck 2 bbl carb actually flows better than a 4bbl so unless you want to do heads, cam & intake just go with the headers - you won't be dissapointed.
Old Sep 15, 2011 | 06:59 PM
PaulS's Avatar
PaulS
The stock two barrel flows 300 - 350 cfm and the standard four barrel (Holley 1850) flows 600 cfm. It inly flows 300 cfm if you don't open the econdaries though.
The "best" way to upgrade depends on your budget, how far you want to "upgrade" and what you will be using it for.
Power upgrade can be headers and a carb or headers, cam, intake, carb and a distributor or a 460 and C6 swap with new disc brakes, 6 speed manual, taking 1000 pounds out of the car, installing a roll-cage in it and tubs and shortened axles.
For cheap upgrades (the two don't actually go together) new ignition, headers and a dyno tune will give you a bit more.
Paul
Old Sep 15, 2011 | 07:41 PM
jspagna1's Avatar
jspagna1
Pretty much what everyone else suggested above. Get that motor to breath better and you'll see a great inprovment in perfomance.
Old Sep 16, 2011 | 04:47 PM
LCC's Avatar
LCC
Originally Posted by jlg2002
I agree with JMD but you'd be surprised how much a set of headers and a dual exhaust will wake up an stock engine. - you won't be dissapointed.
Let the engine breathe better, in - out. Not only will you get better power you can feel but the car will sound stronger. The carb shouldn't bigger than a 600cfm, the stock 302HO motor from the 80's had a throttle body comparable to 550 CFM with crappy headers and 2.25" exhaust and it made 225HP.
Old Sep 18, 2011 | 11:00 AM
GT350R Klone's Avatar
GT350R Klone
The word upgrade is pretty open ended.
budget: carb, intake, air cleaner, headers, exhaust.
bigger budget: add aluminum heads
BIGGER BUDGET: swap out the motor for a 351W stroker or big block
jwog666
Dec 27, 2021 08:09 PM
Dokilar
15
Oct 16, 2015 08:13 PM
ChampInSD
Oct 2, 2015 04:55 AM
Boostaddict
Lethal Performance
Oct 1, 2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
Oct 1, 2015 08:57 AM
