radiator reccomendations
so it dawned on me as to why i was having cooling issues, and it was because i have my radiator that i purchased for my stock 289 trying to cool my performance 302... so i was wondering if anyone could point me towards a good radiator i could buy that wont break the bank(looking to spend around 200$) that will keep my engine running smooth and cool. thanks in advance
Easiest way would be to get a stock replacement rad. with more or larger cores as mentioned and keep the outlets where the are.
You may have to use a different timing cover for the right hand exit water pump depending on what the back of your current water pump looks like (backing cover or open) and you'd need to research which year pump to use as the later ones are reverse rotation. I think the early right hand exit started in '70?
Jon
Jon
i found this on summit and the inlet/outlet match up, and it is larger than my radiator, i would just have to worry about how to mount it up but that wouldnt be difficult at all... what do u think?
http://www.summitracing.com/parts/SGT-CU340/
Talk to http://www.championradiators.com/page/400607626 they have a 3 core but its out of stock or get one from http://www.mustangdepot.com/OnLineCa...g/radiator.htm
