liquid wrench?
Old Mar 8, 2006 | 12:29 AM
Scott H.'s Avatar
Scott H.
Default RE: liquid wrench?
If your car is still drivable, take it to a gas station and see if someone can throw an impact on that one lug nut.
You'll probably end up replacing that one lug and lug nut, as the threads will normally pull and bind up in the lug nut.
Good luck with it.
Scott
Old Mar 8, 2006 | 12:32 AM
baddog671's Avatar
baddog671
What he said^^ any service shop that rotates tires could take it off cheaply or for free..
Old Mar 8, 2006 | 09:01 AM
tylerdru's Avatar
tylerdru
Its not drivable right now. If it doesnt come off then i will just buy an impact wrench.
Old Mar 8, 2006 | 11:44 AM
pwhit's Avatar
pwhit
PB Blaster and a 4 way lug wrench. PB is so much better than liquid wrench or WD. It will loosen that stuff up quick.
Old Mar 8, 2006 | 12:50 PM
Soaring's Avatar
Soaring
I ♥ Acer
One thing you might try is to soak it good, then hit it with a torch to get it hot. Usually, that will suck the liquid wrench into the threads. I have an impact wrench, but I have found that the star wrench works better. Use a cheater bar (a piece of pipe) to get more leverage.
Old Mar 8, 2006 | 04:50 PM
tylerdru's Avatar
tylerdru
How about a nutcracker. One of the nuts is not even a lug nut. just a normal nut.
Old Mar 8, 2006 | 07:01 PM
Soaring's Avatar
Soaring
I ♥ Acer
Yeah, that'll work too. What kind of numbskull would out a regular nut on a wheel?
Old Mar 8, 2006 | 09:23 PM
JBradley500's Avatar
JBradley500
after you spray it, work it back and forth just to make sure you dont break off your threads.
Old Mar 8, 2006 | 09:33 PM
tylerdru's Avatar
tylerdru
I got them with a four way, nut blaster and my body weight.
Old Mar 9, 2006 | 12:44 AM
Soaring's Avatar
Soaring
I ♥ Acer
[sm=closed.gif]
