Disc brake update.
Old Mar 13, 2006 | 09:38 PM
tylerdru's Avatar
tylerdru
Default Disc brake update.
I have got everything mounted to the wheel but the calipers. I really dont know how assemble the calipers and attach them to the spindles. I am doing the granada swap. does anyone have any good links with pictures?
Old Mar 13, 2006 | 10:20 PM
popper's Avatar
popper
Default RE: Disc brake update.
Here's some pics I found:
http://www.mustangsteve.com/granadadiscs.html
Hope it helps. I'll be going through this soon.
Old Mar 13, 2006 | 10:29 PM
tylerdru's Avatar
tylerdru
Thanks that helped a good bit. Now i know that the pads need to go on the brackets first.
Old Mar 13, 2006 | 11:46 PM
FordMustangXBA's Avatar
FordMustangXBA
I did a switch on the fronts of my '66 from drums to discs, it took me half a day to do, but it was surprisingly simple. Thank God SSBC provides good instructions. An ape could have done it with those instructions. Good luck with the rest of yours.
Old Mar 14, 2006 | 10:24 AM
popper's Avatar
popper
Tylerdu-
You know, I just noticed on MustangSteve.com it says you'll need to trim the steering stops and cut length off the tie rod adjusting threads. I thought this was a straight bolt on.
Rich
Old Mar 14, 2006 | 03:37 PM
tylerdru's Avatar
tylerdru
I know you may need to shorten the steering stop. No big deal just use a grinder or saw-zall.
Old Mar 14, 2006 | 06:04 PM
degins's Avatar
degins
ORIGINAL: popper
Tylerdu-
Rich
The steering stop pads on Granada spindles are located the same as original 65-73 spindles. The tie rod issue concerns a small percentage of 65-66 Mustang and 63-65 Falcon only. Some of these cars require more toe-out than is available with Granada spindles and Mustang ajustment sleeves. Using Granada adjustng sleeves usually fixes the problem.
Old Mar 14, 2006 | 09:02 PM
popper's Avatar
popper
ORIGINAL: degins
ORIGINAL: popper
Tylerdu-
Rich
OK, thanks for clearing that up Dennis.
Rich
lincolnshibuya
Oct 6, 2015 08:45 AM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
guitarman376
Sep 30, 2015 05:54 PM
Sep 25, 2015 06:42 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
