8.8" swap
Old Mar 14, 2006 | 03:53 PM
FoRdBoY357's Avatar
FoRdBoY357
Default 8.8" swap
why wont it work?!?!?!?!?!?!??!?!?! it is the right width (54") and it has disk brakes!! i do know that the center section is off center about 4" why should this make a difference?
Old Mar 16, 2006 | 10:45 AM
stangsrdashit's Avatar
stangsrdashit
Default RE: 8.8" swap
bump
Old Mar 16, 2006 | 11:55 AM
Soaring's Avatar
Soaring
I ♥ Acer
8.8" rears come with axles that are 59.5" wide.
Old Mar 16, 2006 | 05:36 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
ORIGINAL: FoRdBoY357
u must have a a truck axel! its would work if the chunk was centered and u welded perches on it!
Old Mar 17, 2006 | 01:06 AM
THUMPIN455's Avatar
THUMPIN455
There is a thread on it detailing the install. Search the forum for it, he has good info.
Old Mar 21, 2006 | 03:11 PM
FoRdBoY357's Avatar
FoRdBoY357
it is 54", i measured.....and it came out of a v-8 explorer (disk brakes limited slip )
Old Mar 21, 2006 | 04:43 PM
pwhit's Avatar
pwhit
He is right guys, the 8.8's from the Explorer's are ~54" (actually 53 3/8") w/ the pumpkin ~3" off center. The only reason I know is that I am a transplant from the Jeep group and this is a very common swap into the Wrangler.
Here is a write up that is not pertaining to this site but it may help in the calculations for bracket placement for anyone who is welding brackets to a bare axle.
http://www.stu-offroad.com/axle/8.8axle/8.8axle-1.htm
I'm not sure if the pumpkin being off center would affect anything. I do know for Jeeps that the 8.8 out of the Mustang would not work due to the location of the pumpkin. So I would probably say the same proble would occur in a swap the other way.
Hope this helps
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Bokeo
Oct 10, 2015 08:28 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
guitarman376
Sep 30, 2015 05:54 PM
UrS4
Sep 30, 2015 10:13 AM
