rear springs
Just started trying to take my rear springs out. I got the nuts off on the front bolt but cant get the bolt out. On one side I got it to turn alittle. I was just wondering if I should just cut them on either side of the spring? whats the easiest? Also, how does the axles come out? it is a ford 8" rear. do you just take the 4 nuts out that are on the backing plate? Thanks alot!
The front bolts are rusted in. You have to use a sawzall (reciprocating saw) to cut the bolt on both the inside areas. Here is a pic of mine after I got it out. And, once you get the leaf springs off, the only other thing holding the rear on the car is the drive shaft.
ORIGINAL: 67t5ponycoupe
Try beating the bolt out first. It will be much easier if it will come out. Go to the sawsall if that fails. it will take a while with the saw.
The problem is you can't get a good straight smack on it with a BFH. You gotta hit it at an angle. If you could get straight on it these things would never be an issue but as any one who has done these will tell you "it sucks 99% of the time" 1% is still worth a shot
