rear springs
Old Mar 14, 2006 | 10:57 PM
67t5ponycoupe's Avatar
67t5ponycoupe
Default RE: rear springs
True that!
Old Mar 14, 2006 | 11:10 PM
tylerdru's Avatar
tylerdru
Has anyone tried an air hammer to slice the bolt?
Old Mar 14, 2006 | 11:17 PM
Soaring's Avatar
Soaring
I ♥ Acer
'splain that tool Tyler.
Old Mar 14, 2006 | 11:19 PM
tylerdru's Avatar
tylerdru
they make muffler cutoff tools and everything for air hammers.
Old Mar 14, 2006 | 11:37 PM
67t5ponycoupe
Those are not really made to do anything as thick as a bolt. Those bolts on the leaf springs are hardened and I'll bet they are as hard or harder than the bits for that air chistle.
Old Mar 14, 2006 | 11:38 PM
67t5ponycoupe
Sounds like a receipe for pain.
Old Mar 15, 2006 | 10:49 AM
67Dan67's Avatar
67Dan67
Thanks that is what I was thinking. I will try the BFH first. Hopefully it works. How does the axles come out on the 8" rear? The axle seals are leaking. Thanks alot for the help guys!
Old Mar 15, 2006 | 05:43 PM
saiuto's Avatar
saiuto
If you get a good air hammer it'll blow through a bolt and not even be phased. However, I got mine out by using an air hammer in the same manner you would use the BFH. Just get it as straight as you can and let 'er rip. It'll pound itself a little groove in the end of the bolt, so after a few blows you don't have to worry about it slipping off. It took me about 2.5 minutes to get them out.
Gene K
Oct 21, 2015 11:37 PM
Sep 16, 2015 07:53 PM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
Sep 8, 2015 11:50 AM
Sep 1, 2015 08:16 PM
