Backfire
Old Mar 15, 2006 | 09:21 PM
badazz68stang's Avatar
badazz68stang
Default RE: Backfire
its an edelbrock 600 carb. so it has no power valve to blow out and it isnt over-carbureated for my 289. whoever said timing i think you are right but i will put the light on it tomorow and get it all sorted out, thanks for the help guys.
Old Mar 15, 2006 | 09:24 PM
tylerdru's Avatar
tylerdru
if you are stock then yes you are over carbureted. I am over carbureted i got a holley 600 cfm. I regret it.
Old Mar 15, 2006 | 09:31 PM
tylerdru's Avatar
tylerdru
Infact how much do you think i could sell my 600 cfm Holley 4bbl 4160 electric choke for?
Old Mar 15, 2006 | 09:43 PM
badazz68stang
i dont think im overcarbuerated, its matched up pretty well with my edelbrock intake. and besides, its not gonna cause it to back fire like i am talking.
Old Mar 15, 2006 | 09:46 PM
Soaring's Avatar
Soaring
I ♥ Acer
Do a simple test if you own a heavily carburated car. Pull the dipstick and smell the oil. If you notice a fuel presence (scent) it's time to change the oil and downsize the carb. My suggestion about the water in the fuel is still my best sugestion for fixing the problem if your timing is set correctly.
Old Mar 15, 2006 | 09:49 PM
tylerdru's Avatar
tylerdru
I am already looking for a smaller edelbrock.
Old Mar 15, 2006 | 09:50 PM
badazz68stang
thanks alot soaring, i'll check the dipstick and change the oil i prolly have some gas wash down in the oil from the last time i flooded it out. but im sure it is because of timing. my grandfather is bringin his light over in the mornin along with a mig welder, so looks like im gonna have plunty to do in the next few days.
Old Mar 15, 2006 | 10:37 PM
slickman's Avatar
slickman
I was running a Holley 600 on my 302 which only has (for now) an Edelbrock intake. It was always backfiring. I'm not sure if it was too much carb or if the valve blew. I went out and purchased a NEW Edelbrock 500 (I like their carbs) and the problem is gone..
ORIGINAL: badazz68stang
Old Mar 16, 2006 | 07:15 AM
tylerdru's Avatar
tylerdru
Im gonna raise hell if my mustang runs fine after i get an edelbrock.
Old Jul 2, 2006 | 04:05 PM
silver302's Avatar
silver302
Any feed back on the edelbrock carb change? Ive been having the same problem with a '70 302, Edelbrock manifold, Holly 600 cfm carb. Idles ok, smooth acceleration unless I punch it- than it backfires through the carb. Ive tried making the mixture richer etc. Still no luck-
Also had /have stalling problems from stops when starting on an incline-
Being at least the 3rd owner- Im not sure what else has been done to the car (or when)
R
Sean
Aug 15, 2004 03:50 PM
Disgustang
Jul 27, 2004 09:43 AM
Obsol3te
Jul 26, 2004 08:42 PM
spuckie
Nov 21, 2003 05:51 PM
tchamber
Nov 9, 2003 05:47 AM
