Front springs
Old Mar 16, 2006 | 01:21 AM
67Dan67's Avatar
67Dan67
Default Front springs
Just wondering if the springs from a car with a 302 are the same as a 351? is there a big weight difference? Thanks
Old Mar 16, 2006 | 06:57 AM
65_2plus2's Avatar
65_2plus2
Default RE: Front springs
No they're not the same, the 351 is heavier.
Old Mar 16, 2006 | 11:03 AM
67Dan67's Avatar
67Dan67
What would you recommend if I had a 302 with 351 heads? Aren't they pretty much the same block? Thanks
Old Mar 16, 2006 | 08:15 PM
Shifty101Easy's Avatar
Shifty101Easy
nah, they are differnt blocks.......
260-289-302-331-347 etc is the same block.....
a 351 is a step above.....but i think the heads still bolt onto the other block.
Old Mar 16, 2006 | 08:21 PM
daver's Avatar
daver
351 has a taller deck and bigger mains.
Old Mar 17, 2006 | 04:10 AM
65_2plus2's Avatar
65_2plus2
But, as to the original question. The 302 springs will be fine with a 302 engine, with 351 heads. Or if you wanted to save some more weight, get a set of aluminum heads.
Cheers.....[sm=icon_cheers.gif]
Old Mar 17, 2006 | 02:11 PM
THUMPIN455's Avatar
THUMPIN455
The differnce isnt enough to realy cause problems on a healthy suspension, swapping in a 351 wont make the front crossmember drag the ground or anything. Now a 460 is another thing entirely.
Old Mar 17, 2006 | 04:30 PM
67Dan67's Avatar
67Dan67
Well the problem I have is that I have 351 springs in a 67 with a 302 w/ 351 heads. It sits high in front or low in the back but I cant tell. My rear springs are original so I am assuming that they are sagging in the rear. But it also could be from the 351 springs in the front. Thanks alot.
Old Mar 17, 2006 | 04:41 PM
muggsy's Avatar
muggsy
Keep in mind that 67's (and most others for that matter) are high in the front to begin with. I have a 289 w/original springs and it looks like its pointing up a bit, as do all other photos I've seen of 67s. That's why most of the suspension kits sell with a one inch front end drop, and it looks like it sits more evenly with that.
Old Mar 17, 2006 | 06:52 PM
Soaring's Avatar
Soaring
I ♥ Acer
Yeah, new 1" drop springs along with new KYB gas adjust shocks will do wonders to tighten up control of the front. Then add some new 1" sway bars. Throw some new leaf springs in the rear with KYB's and sway bars.
