Front springs
Old Mar 18, 2006 | 07:54 PM
67Dan67's Avatar
67Dan67
Default RE: Front springs
Is the 1" sway bar dropped also or is it bigger? Thanks alot for all the help! Oh also, the kyb gr2 shocks. Are they any good or would you go with the more expensive ones. Thanks
Old Mar 18, 2006 | 08:04 PM
redstallion's Avatar
redstallion
your stock '67 has a 3/4" sway bar.....
put a 1" sway bar in the front and a 3/4" in the rear along with the kyb gas-a-just shocks.....along with a set of 1" drop springs.....it will handle like a totally different car
i've done all of the above except the drop springs, but i will do those soon.
Old Mar 18, 2006 | 08:22 PM
67Dan67's Avatar
67Dan67
What comes stock in the rear for a sway bar? The 3/4" inch? Thanks
Old Mar 18, 2006 | 08:28 PM
redstallion
there was no sway bar in the rear
Old Mar 18, 2006 | 09:03 PM
67Dan67's Avatar
67Dan67
So you just get a kit? where do you get them?
Old Mar 18, 2006 | 09:12 PM
popper's Avatar
popper
There's an interesting discussion on suspension upgrades over at Stangnet...
http://forums.stangnet.com/showthread.php?t=622994
Some seem to think a rear sway bar on a classic mustang isn't the answer.
And some seem to think roller spring perches should be high on the to-do list.
Just passing info. along... I have no personal experience with this stuff.
Old Mar 18, 2006 | 09:14 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: 67Dan67
Just about any Mustang vendor will have the 3/4 sway bar kit for the rear. Bear in mind, that there are many variations. So, depending on your use of the car will determine which one you want to buy. Here is a typical rear sway bar kit. Just type in rear sway bar in the search, and the year of your car. http://www.parts123.com/PartFrame.as...=Texas_Mustang
Old Mar 19, 2006 | 10:11 AM
muggsy's Avatar
muggsy
How would you describe the KYB Gas Adjusts: Stiff as hell, or somewhat firmer ride vs stock etc. ?
Old Mar 19, 2006 | 02:40 PM
redstallion
more firm than stock but not "stiff as hell"........great shocks IMO
4cylinderplus2
Oct 9, 2020 07:45 PM
baddog671
Jul 26, 2016 01:20 PM
marc954
Sep 29, 2015 11:18 AM
mungodrums
Sep 28, 2015 10:54 PM
