Brakes
Old Mar 16, 2006 | 06:55 PM
68Midnight's Avatar
68Midnight
Default Brakes
This might e a dumb question but its ok, im new.
I noticed my brakes went out today...slowly....and t made me think "oh must be out of fluid".
Do I have brake fluid? Where is the brake fluid holder if so?
Its a 68 coupe/289/drums all around.
Thanks!
Nathen
Old Mar 16, 2006 | 07:09 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Brakes
Open your hood, and look on the firewall right in front of the steering column. There will be a master cylinder attached to the firewall. If it has run out of fluid, you will now have air in the lines, and will have to bleed the brakes after you add some new dot3 fluid.
Old Mar 16, 2006 | 08:10 PM
68Midnight's Avatar
68Midnight
Default RE: Brakes
ah...found it, and its empty. ill have to fix that tomrrow. Thanks!
Old Mar 16, 2006 | 08:19 PM
daver's Avatar
daver
Default RE: Brakes
But beware, brake fluid is not something that you should be going through regularly
Old Mar 16, 2006 | 10:58 PM
ideal_mustangs's Avatar
ideal_mustangs
Default RE: Brakes
There is definatley a leak somewhere if it went down. That is unless it's been sitting for years. Put fluid in them and pump it up and have someone look under the car for leaks.
Old Mar 17, 2006 | 02:26 PM
68Midnight's Avatar
68Midnight
Default RE: Brakes
I did notice something leaking and it wasnt tranny fluid/oil. Im betting its probably the brake fluid.
b8checker
Oct 8, 2015 12:55 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
guitarman376
Sep 30, 2015 05:54 PM
Sep 25, 2015 06:42 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
