Quarter Panel...Time for Replacement???
Old Mar 16, 2006 | 10:36 PM
Craig67's Avatar
Craig67
Default Quarter Panel...Time for Replacement???
Hey guys. I just got my mustang, and the quarter panel looks pretty bad. I have some pictures of it. Basically, is there any type of body work I can do without replacing it, or is it time to just weld on a new one?
[IMG]local://upfiles/32389/A6695AC17FB244F69454BFBBC6CB0462.jpg[/IMG]
Old Mar 16, 2006 | 10:58 PM
Shifty101Easy's Avatar
Shifty101Easy
Default RE: Quarter Panel...Time for Replacement???
anything can be fixed almost....but would it be easier to just get a new quarter panel welded on....perhaps...you should talk to a body shop...someone on here will probably know too and answer later....
Old Mar 17, 2006 | 02:19 AM
Craig67's Avatar
Craig67
Alright, thanks.
Old Mar 17, 2006 | 12:12 PM
slickman's Avatar
slickman
That looks like it has been worked on a few times. If it were me, I would just get a new qtr and replace it. You will more than likely find other things needing to be replaced as you do the work.
Old Mar 17, 2006 | 12:48 PM
mayh3m's Avatar
mayh3m
do not bondo that. you can replace the entire quarter panel as suggested, or simple replace the lower portion around the wheelwell. i believe places sell just that section around the well because it's what goes bad most of the time. search for it. both of mine looked just liked that, and i opted to do it correctly and replace both quarter panels entirely. up to you.
Old Mar 17, 2006 | 03:54 PM
Craig67's Avatar
Craig67
Alright. Replacements it is. It's what I was planning in the first place, but if there was something easier out there...
Old Mar 17, 2006 | 08:32 PM
Ste7of1's Avatar
Ste7of1
Mayh3m,
when you say replace entire quarter panel are you referring to welding a section around the wheel or did you replace the fender all the way to the door?
Old Mar 17, 2006 | 08:38 PM
Twister's Avatar
Twister
ORIGINAL: Ste7of1
Mayh3m,
door to tail lamp panel, rocker to pilar
Old Mar 17, 2006 | 09:21 PM
Soaring's Avatar
Soaring
I ♥ Acer
You can't really tell what is under that paint. To save yourself some grief, I would just replace the entire quarter panel. The difference in cost of welding in a new section, and welding in a whole panel would be minimal to comparable , and we all know that labor cost of welding is the biggest expense if you can't do it yourself.
Old Mar 17, 2006 | 11:45 PM
mayh3m's Avatar
mayh3m
i was referring to a quarter panel skin. more than likely, that's the only part that is rusted. however, my passenger side had a rusted wheelwell too, but we just made a patch panel for it. some pictures:
