Heater Core Leak
Old Mar 17, 2006 | 12:37 PM
astout3927's Avatar
astout3927
Default Heater Core Leak
Just recently the heater core on the inside of my 65 mustang on the passenger's side has been leaking for no reason. I tried to use a radiator sealant but after a while it started leakin that stuff too. Can somebody tell me what's up?
Old Mar 17, 2006 | 01:06 PM
bdwjdw's Avatar
bdwjdw
Default RE: Heater Core Leak
Heator cores over time get corroded and rust out. Thats why it's leaking. The only fix is to put a new one in.
Old Mar 17, 2006 | 02:56 PM
saiuto's Avatar
saiuto
^^^ What he said. Also, once you replace the heater core, take it in and have the cooling system flushed. A lot of times those radiator sealant/stop leak products will clog up the system. Typically you want to avoid using stuff like that on a car you want to keep.
Old Mar 17, 2006 | 03:02 PM
Soaring's Avatar
Soaring
I ♥ Acer
Ditto what they both said, but make sure you aren't just leaking from the hose connections first.
4cylinderplus2
Oct 9, 2020 07:45 PM
mrtrodonet
Sep 19, 2020 03:12 PM
bradleyb
Nov 27, 2015 07:50 PM
jerrytubes
Oct 23, 2015 12:11 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
