Body work difficulty
Old Mar 19, 2006 | 12:52 AM
badazz68stang's Avatar
badazz68stang
Default Body work difficulty
HAs anyone ever replaced the lower door skin? if so how long did it take and maybe share some advice and guidance.
Has anyone replaced the tailight panel on a 1968 coupe? Ditto, how long and advice?
Old Mar 19, 2006 | 01:16 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
Default RE: Body work difficulty
measure, measure and take ur time. the time to complete the job depends on ur skill level! its better to take a day for it to look right than an hour and it to look terrible!
Old Mar 19, 2006 | 12:59 PM
Soaring's Avatar
Soaring
I ♥ Acer
There's a Tech article in the FAQ on how to replace the door skin.
Old Mar 19, 2006 | 01:29 PM
badazz68stang
there is only a small rust place at the front of the door, maybe the size of a 50 cent piece in diameter, would it just be easier to make my own smaller patch and do it that way? the rest of the door is in good shape with no dents or rust.
Old Mar 19, 2006 | 09:00 PM
THUMPIN455's Avatar
THUMPIN455
The problem with a small rust hole is that the affected area is much larger. A quarter sized hole might be 6" that need replaced. Its just the only place its all the way thru is right there. Take the door panel off and take a look. If you can put a screwdriver through it then it needs replaced for sure. Finding good metal around that can be tough.
djbigskrilla
Sep 20, 2022 01:04 AM
Sep 16, 2015 02:11 PM
dochawk
Aug 25, 2015 08:25 AM
stanngg
Aug 12, 2015 03:43 PM
cema93
Aug 10, 2015 09:35 PM
