Cam timing?????
Old Mar 19, 2006 | 03:29 PM
slickman's Avatar
slickman
Default Cam timing?????
I'm going to be installing the Comp Cams # XE262H in my 302 along a few other things like heads. Should I advance the cam timing or run it straight up?
Old Mar 19, 2006 | 04:40 PM
daver's Avatar
daver
Default RE: Cam timing?????
It all depends, each way will get you somethin different, im not sure of what it is exactly, but if you advance it it will give you either more HP er more Torque, the same with retarding it. It either that or it moves your power band up or down. I dont know all the specifics but there is somethin for you to research
Old Mar 19, 2006 | 08:16 PM
fast66's Avatar
fast66
Slickman. Get a timing wheel, and set up the cam so it matches the specs straight up. There is sometimes a little error in cams, and this can be corrected with a multi keyway timing set. from memory theres a good instruction sheet for timing a cam on the edelbrock site.
Old Mar 19, 2006 | 11:46 PM
daver's Avatar
daver
From what ive read Comp Cams grinds their cams 2degrees in advance, so when you install it "straight up" it is actually advanced 2 degrees already. Oh and i did some research and all advancing does is move your powerband down the RPM scale. Retarding it moves it up.
Old Mar 20, 2006 | 07:30 AM
slickman's Avatar
slickman
Cool, I had planned on installing it straight up so that's great.
ORIGINAL: daver
Old Mar 20, 2006 | 06:35 PM
Grimace5.0's Avatar
Grimace5.0
I ♥ Acer
http://compcams.com/Technical/Instru.../Files/145.pdf
http://compcams.com/Technical/TimingTutorial/
Luke9222
Oct 22, 2015 11:55 PM
mungodrums
Oct 7, 2015 04:01 AM
raleigh05GTO
Sep 4, 2015 07:09 AM
Luke9222
Sep 4, 2015 06:46 AM
