brake drum problems
Old Mar 19, 2006 | 05:54 PM
medicman's Avatar
medicman
Default brake drum problems
can anyone tell me how to seperate the hub from a brake drum? thanks, wendell.
Old Mar 19, 2006 | 05:57 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: brake drum problems
You need to loosen the shoes. There is a slot that you can either use a special tool, or a screw driver to loosen the adjustment wheel. It is an oval hole that may or may not have a cover over it. Once you get the shoes loosened, tap the drum gently with a hammer, then wiggle it until it comes off.
Old Mar 19, 2006 | 07:07 PM
67t5ponycoupe's Avatar
67t5ponycoupe
If the drum and hub are off the car just punch the studs through.
Tivo304
Aug 28, 2023 12:19 PM
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
mungodrums
Oct 7, 2015 04:01 AM
musnicki
Sep 23, 2015 07:11 AM
