I need leaf spring opinions
Old Mar 21, 2006 | 11:09 AM
bryanvw61's Avatar
bryanvw61
Default I need leaf spring opinions
time to replace my rear leaf springs, but with some many options (Blocks, standard, mid, reverse eye, and 4, 4 1/2, 5 leafs) i wanted to seek some opions.
this is what i got... the car is an I6 with a c4, it will be a 302 with a T5 next winter, right now i'm putting the 6 back in to get it registered. currently i have global west control arms up front (1 3/16" lower mounting holes) and grab a track 620# 1" drop coils and a 1" sway bar working with my granada swap spindles. and in the rear i have a 3/4" sway bar and an 8" rear waiting for the V8. I have KYBs all arround...
what leaf and block combination would you reccomend?
Thanks!
Old Mar 21, 2006 | 01:36 PM
groho's Avatar
groho
Default RE: I need leaf spring opinions
Try http://www.mustangsteve.com/rideheight.html to get some ideas. Just finished my 66 with 620's/mid-eye, no shelby drop. It currently sits level. The pic's help. BTW, what year stang? There's a 1000 lb dif in GVW between 65 and 73. That will have an impact.
Old Mar 21, 2006 | 04:40 PM
bryanvw61's Avatar
bryanvw61
mine's a 66 and i use steve's site a lot to help me figure things out
Old Mar 21, 2006 | 04:51 PM
Soaring's Avatar
Soaring
I ♥ Acer
I have a 65, 289 with an 8" rear. I put on standard eye 4 leaf springs last summer, and it leveled mine out. I have not dropped the front yet.
Old Mar 22, 2006 | 02:30 PM
bryanvw61's Avatar
bryanvw61
i wondering from a performance stand point as well
Old Mar 22, 2006 | 09:36 PM
Soaring's Avatar
Soaring
I ♥ Acer
Some strong sway bars and a good set of shocks will tighten up the rear. If you use 5 leaf springs, be expecting a rough ride.
http://www.mustangsplus.com/Merchant...=Sway_Bar_Kits
Old Mar 22, 2006 | 10:28 PM
ttoney's Avatar
ttoney
I would say that it depends upon your goal. I have a very similar front setup (1 1/4 sway, 1 3/16" drop, camber wedges, eccentric elim, no tcp). In the rear I have a 9" with reverse eye 1 1/2 drop 5 leaf springs, 7/8" sway, and KYB gas adj.
The car sits pretty level. I'll tell you one thing, I am certain that I would have softer suspension if I welded it all solid.
Some people might not like the ride but I love it. Coupled with 4 wheel disks and the 5 speed the car is Incredibly responsive. IMHO, you should do up the rear to match the front. If not you will have some wacky handling characteristics. You should probably go with at least 4 1/2 leaf, NO blocks.
Old Mar 22, 2006 | 11:27 PM
Soaring's Avatar
Soaring
I ♥ Acer
Tell us about that theory. Just curious.
Old Mar 22, 2006 | 11:33 PM
dodgestang's Avatar
dodgestang
ORIGINAL: ttoney
CauseKYB gas adj.
EffectI'll tell you one thing, I am certain that I would have softer suspension if I welded it all solid.
I used to run the KYB...I felt I was making an informed comprise of soft ride for responsivensss. I switch to the eldebrock IAS and WILL NEVER EVER buy a KYB gas a just again in my life. I run 5 leaf, 620s, sway bars, 17 inch rims....but I added in roller perches and the shocks...and it is night and day...more responsive and much more enjoyable ride feel.
Just sharing
As for the leaf choice, given the drop you have in the front end already 4.5 mid eyes would prob suit your needs.
Old Mar 22, 2006 | 11:43 PM
Soaring's Avatar
Soaring
I ♥ Acer
What sway bars are you running in the rear Nick?
