gas gauge doesnt work
Old Mar 24, 2006 | 11:56 PM
farkedup's Avatar
farkedup
Default gas gauge doesnt work
Are there any common reasons for this? Trying to figure out where to start checking before I get into it.
Old Mar 25, 2006 | 12:21 AM
Iskwezm's Avatar
Iskwezm
Default RE: gas gauge doesnt work
first, take the sender wire off the tank and ground it, the gauge should read past full, if not the sender is bad or the wire, if it reads full, then you have a issue with the gauge. I fired my IVR and have been tracing mine for over a month and its only 2 wires
Old Mar 25, 2006 | 12:31 AM
ngirg001's Avatar
ngirg001
got the same problem, which one is the sender wire
Old Mar 25, 2006 | 12:57 AM
farkedup's Avatar
farkedup
Found this:
http://www.mustangandfords.com/techarticles/75259/
In the FAQ of all places... the key part being the Fuel Gauge section
Old Mar 25, 2006 | 05:07 AM
Craig67's Avatar
Craig67
haha, there you go. That's all the info you need...and then some!
Old Mar 25, 2006 | 07:31 PM
farkedup's Avatar
farkedup
Is there an "easy way" to get to get to these wires?
Old Mar 25, 2006 | 07:39 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: farkedup
What? The sending unit wire? Just crawl your butt under the gas tank and take the wire off the sending unit. Ground it on the chassis and see if the gauge pegs.
Old Mar 25, 2006 | 07:41 PM
farkedup's Avatar
farkedup
I'm fat LOL was hoping to dodge getting the jack out......
Old Mar 25, 2006 | 07:47 PM
Soaring's Avatar
Soaring
I ♥ Acer
Then it's time for a diet fat boy. And, as far as getting the jack out.......now, that is just pure laziness.
Old Mar 25, 2006 | 08:03 PM
farkedup's Avatar
farkedup
That would be why I'm fat I'm going to go out and do it as soon as grandma gets here to watch the baby....
