gas gauge doesnt work
Old Mar 25, 2006 | 09:23 PM
66ckurt's Avatar
66ckurt
Default RE: gas gauge doesnt work
ya i had that same problem it was the sender unit its self and i recomend changing the unit no matter what, its cheap and when i pulled mine out the filter had been eaten up it wasn;t pretty.
Old Mar 25, 2006 | 11:02 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: 66ckurt
The filter on the sending unit is a "sock" and is easy to replace.
Old Mar 25, 2006 | 11:05 PM
farkedup's Avatar
farkedup
I have a full tank of gas... I found the place where 2 lines came out of the tank.
Is this something I should do with very little gas in the tank? I tugged a little and it didn't slide right out or anything. I also apparently have a super slow leak because there was a little moisture around it and it smelled like gas.
Old Mar 25, 2006 | 11:17 PM
Soaring's Avatar
Soaring
I ♥ Acer
You either have a drain plug or you don't. If you do, then just drain all the fuel out and replace the sock, or the sending unit as a whole. If you don't have a drain plug, then siphon out as much as you can, then take the sending unit out. You will need a buclet underneath the unit to catch the gas.
Old Mar 25, 2006 | 11:46 PM
farkedup's Avatar
farkedup
Glad I didn't try to get it out much LOL would have SUCKED to lose 16 gallons... I think I'll wait till I drive around 100miles or so.
Syphoning sucks and catching with a bucket does too LOL
67LimeCoupe
Nov 25, 2015 08:55 PM
movielover40
Aug 27, 2015 10:13 PM
unit91
Aug 21, 2015 11:44 PM
jjwinel78
Aug 17, 2015 03:34 PM
HIS S-197
Aug 10, 2015 05:47 PM
