I need transmission Help!!
Old Mar 25, 2006 | 12:03 PM
slickman's Avatar
slickman
Default I need transmission Help!!
I have an NEW AOD that I'm going to install in my 66. I'm trying locate were to purchase a neutral safety switch (can't seem to find them). Also were does the TV cable attach?? I did find a plug were you're suppose to adjust the pressure but, I don't see anyplace to hook up the TV cable....
HELP!!
Old Mar 25, 2006 | 12:25 PM
THUMPIN455's Avatar
THUMPIN455
Default RE: I need transmission Help!!
You have to get a bracket to mount the TV. Early 80s Fairmonts and other non injected engines will have the bracket you need. Some aftermarket universal type brackets can be made to work, but you have to get the right amount of cable pull from the throttle lever, so bracket placement is important. You wont have anything you can use on a stock pre 78 Ford.
As for the neutral safety switch, you will most likely have to use an aftermarket type since the stock one for your car was on the trans. What shifter do you plan on using? You could mount one on the shifter so it has to be in Park to start, thats the way I wired up the one in my race car
Old Mar 25, 2006 | 12:46 PM
slickman's Avatar
slickman
I have a Lokar TV cable for the AOD, the thing I don't see is were on the tranny the other end of the cable connects. I know on my C4 there is a rod in the center of the shift lever for the kick down. I don't see anything like that on the AOD. As to the safety switch, do you know were I can get an after market?
ORIGINAL: THUMPIN455
Old Mar 25, 2006 | 02:26 PM
THUMPIN455's Avatar
THUMPIN455
Can you post a pic of the trans? The TV cable should be on the passenger side by the dipstick tube. If there isnt one there then you have an AODE or some other transmission. The AODE is electronically controlled for shifts, line pressure, etc. so it doesnt have a TV cable.
Old Mar 25, 2006 | 03:58 PM
67t5ponycoupe's Avatar
67t5ponycoupe
What the heck is a TV cable?
Old Mar 25, 2006 | 04:03 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: 67t5ponycoupe
That's so you can put a television in the dash. No, it's the throttle valve mechanism. Maybe this info will help.
http://www.fourthgearinc.com/Technical_Info.htm
Old Mar 25, 2006 | 04:04 PM
67t5ponycoupe
Ok, throttle valve cable. Now it makes sense.
Old Mar 25, 2006 | 04:15 PM
slickman's Avatar
slickman
Here are pics.
[IMG]local://upfiles/26659/76B56D9A4B5C448C848F8AA60399A2B3.jpg[/IMG]
[IMG]local://upfiles/26659/7297DA1738794C15AFF7B295CA596959.jpg[/IMG]
Old Mar 25, 2006 | 04:51 PM
Shifty101Easy's Avatar
Shifty101Easy
is the neutral safety switch differnt for a AOD than say...a C4?
if not then they have them in NPD and other places...
Old Mar 25, 2006 | 05:40 PM
slickman's Avatar
slickman
Thanks guys, I found the place for the TV cable. It's in the same place as the C4 only, a big washer was covering the shaft and I did not notice it. So, I just spent some time and gave it a coat of POR-15 Ford blue and here is it all painted waiting to go in!!
[IMG]local://upfiles/26659/C507BAE10831417CAB1D38B64F2098FA.jpg[/IMG]
