Floor Jack and jackstand question
Old Mar 26, 2006 | 11:14 AM
Frank Bullitt's Avatar
Frank Bullitt
Default Floor Jack and jackstand question
What are the best jacking location when using a floor jack to raise the front or rear of a 1968 mustang. And where are the best locations for putting jack stands.
I would appreciate knowing how to properly lift either the front or the rear or both ends of car for working underneath.
Just want to be safe and not damage anything.
Old Mar 26, 2006 | 01:54 PM
acidrain088's Avatar
acidrain088
Default RE: Floor Jack and jackstand question
for the front i would jack it up from the cross member under the engine or one side at a time using the frame rail extensions. i usually put jack stands under the frame rail extensuon but under the suspension arms works if need be. for the rear jack it up from under the rear end housing and ut jack stands under the rear axle on each side
Old Mar 26, 2006 | 02:45 PM
67t5ponycoupe's Avatar
67t5ponycoupe
Concur
Old Mar 26, 2006 | 02:59 PM
Soaring's Avatar
Soaring
I ♥ Acer
I use 6 jack stands whenever I jack my whole car up. I first jack the front driver's side up by using the jacking up location just under the door. You will see a cut-out where the jack fits. I put two stands on that front side. One under the cross member, and one on the frame rail extension. Then I go to the front passenger side and do the same. For the rear, I jack up the pumpkin and put the stands axle. If I need to get it higher, I just put some lumber under the floor jack and repeat the process.
chrisdbassplayer
Oct 13, 2015 06:53 PM
b8checker
Oct 8, 2015 12:55 PM
b8checker
Sep 30, 2015 07:11 AM
treesloth
Sep 28, 2015 07:03 AM
ThatJuanStang
Sep 25, 2015 08:01 AM
