stuff is just falling out
Old Mar 26, 2006 | 10:21 PM
acidrain088's Avatar
acidrain088
Default stuff is just falling out
so here i am lieing on my back feet in the air, working instailling everything with the steering column and a monster spring falls out from somewhere under there. the spring is about 5 inches long and is made of 1/4 inch spring steel. was this hooked up to a petal. it is standard. does this spring sound firmular to anyone.
Old Mar 26, 2006 | 10:32 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: stuff is just falling out
Clutch pedal spring???
Old Mar 27, 2006 | 04:20 PM
superdavid's Avatar
superdavid
I'm betting its the clutch pedal spring if its a manual.
Old Mar 27, 2006 | 09:34 PM
djustham's Avatar
djustham
I have an automatic (65) Fastback and there is a long spring that comes over and attaches to the underside of the passenger floor pan. I am thinking that it might attach to the emergency brake assembly but not sure. I will have to crawl under and take a look.
Old Mar 27, 2006 | 09:42 PM
Soaring's Avatar
Soaring
I ♥ Acer
Yeah, but he is talking about a standard tranny and he is on his back looking up under the dash. It's the clutch pedal spring.
Old Mar 27, 2006 | 09:56 PM
Cogtx's Avatar
Cogtx
Does it look like this? if so..clutch pedal spring...I'm missing this one on my stang but not having any probs w/o it...might replace it someday..
[IMG]local://upfiles/19071/BF4BE97AD0894044B8B5B2195427E015.jpg[/IMG]
Old Mar 27, 2006 | 10:05 PM
superdavid's Avatar
superdavid
BTW, that things a pain in the butt to put back in. We used a jack about 4 hours, and a 2x4 to mash mine into place, then I found out that I didn't need it with my hydraulic clutch kit. I was pretty stinkin mad, so I sawed it in half with a dremel drill.
Old Mar 27, 2006 | 10:12 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: superdavid
That's right, the hydraulic takes the place of the spring. I feel your pain. Next time.....READ.
Old Mar 28, 2006 | 09:35 PM
67t5ponycoupe's Avatar
67t5ponycoupe
For those that are wondering, that spring is there to assist you in holding the clutch pedal to the floor. You can run without it but it makes the clutch pedal much harder. When you install the springs you need to put the clutch pedal to the floor. With the clutch pedal on the floor it takes about 5 minutes to install.
EZFEED
May 5, 2016 08:54 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
AMAlexLazarus
AmericanMuscle.com
Sep 23, 2015 01:14 PM
2015Ecoboost
Sep 17, 2015 01:48 PM
