oil filter
Old Mar 28, 2006 | 04:08 PM
bakerboy's Avatar
bakerboy
Default oil filter
I changed my oil filter (66, 289) with a puralator Pure (nice color blue) and it is leaking. Is ther a better filter? Should I use only Motorcraft? FOMOCO?
Old Mar 28, 2006 | 04:54 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: oil filter
Motorcraft and Wix make good filters for our cars. There are more expensive ones to include Amsoil and Redline, but unless you are running synthetic oil, you will be just fine with either the Motorcraft or the Wix.
Old Mar 28, 2006 | 05:24 PM
ideal_mustangs's Avatar
ideal_mustangs
I run Puralotor on mine also. Just make sure you rub some oil on the new gasket. It helps it to seal better.
Old Mar 28, 2006 | 05:38 PM
highhilleer's Avatar
highhilleer
I doubt your leak is a filter problem. Did you verify that the sealing gasket came out when you took off the old filter? If not you've doubled your gasket, a sure way to get a leak.
Old Mar 28, 2006 | 06:48 PM
serge627's Avatar
serge627
I use a Fram filter in the mustang, and my truck, and my van. Havent had any problems with them.
Old Mar 28, 2006 | 09:31 PM
19stang66's Avatar
19stang66
I read on a website that compared a bunch of different brands of oil filters and they said Fram was the worst.
Heres the link to the thread from StangNet--- http://forums.stangnet.com/showthrea...ght=oil+filter
Heres the link to the website that did the testing--- http://minimopar.knizefamily.net/oilfilterstudy.html
Old Mar 29, 2006 | 10:57 AM
slickman's Avatar
slickman
I agree with Soaring.. Matter of fact Wix filters is one of the best filters out there.. I have a article that goes into details on many filters. I'll out it up on my web site tonight.
ORIGINAL: Soaring
Old Mar 29, 2006 | 08:13 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: 19stang66
Yeah, it has been proven over and over that Fram filters are at the bottom of the quality gauge for filters. That is all you can get at Wally World though, so I suggest you not shop at Wally World for oil filters.
Old Mar 29, 2006 | 08:19 PM
slickman's Avatar
slickman
Okay, here is the oil filter study I have gone by and I always use Wix. Check it out an plan on doing allot of reading..
Oil Study
ORIGINAL: Soaring
ORIGINAL: 19stang66
Old Mar 29, 2006 | 08:56 PM
19stang66's Avatar
19stang66
ummm im pretty sure thats the same link i posted...
