67 fastback
Old Mar 28, 2006 | 05:13 PM
vanceboro's Avatar
vanceboro
Default 67 fastback
Hi every one,
I just became an owner of a 67 fastback. I am preparing it to be painted. I cannot get the hood to fit nicely. Side to side is no problem but it sticks up at the back approx 3/8 above the cowl. the hinges are down as far as they will go. Any suggestions?
Old Mar 28, 2006 | 05:18 PM
ideal_mustangs's Avatar
ideal_mustangs
Default RE: 67 fastback
Mine is like that a little (like the thickness of the hood), and I had it aligned professionally be the body shop that painted it. I've found that I can push the back corners down a little bit after the hood is closed and it will pretty much close the gap up.
Old Mar 28, 2006 | 06:18 PM
highhilleer's Avatar
highhilleer
Do not try this until you research it better, but the solution is to push up at the front of the hood while it is open. This resets the hinges and will lower the back corners when closed. That should be enough to get you started on an internet search. I haven't done or tried this as it was not a problem for me, just recall reading about it.
Old Mar 28, 2006 | 06:56 PM
67Sally's Avatar
67Sally
My 67 coupe does the same thing
Old Mar 28, 2006 | 09:11 PM
67t5ponycoupe's Avatar
67t5ponycoupe
Highhiller is right. Loosen the hinges where they attach to the aprons. Lift up on the hood while retightening the bolts. This will lower the back of the hood.
Old Mar 28, 2006 | 10:23 PM
ttoney's Avatar
ttoney
and what if the back is too low?
Old Mar 29, 2006 | 03:07 AM
KTM's Avatar
KTM
Well in most cases adjusting does not help. Hinges are worn out over the years and only new good quality hinge will eliminate this problem. But does anybody know are these new repro hinges any better than old used hinges?
Old Mar 29, 2006 | 04:51 AM
Shifty101Easy's Avatar
Shifty101Easy
mine does the same thing, a 68, and i just push down the back corners and it lines up perfectly flush.
Old Mar 29, 2006 | 11:48 AM
vanceboro's Avatar
vanceboro
Thanks highhilleer, That process worked for me. I do have to press down a little, but it now fits perfectly Thanks again
Old Mar 29, 2006 | 11:51 AM
vanceboro's Avatar
vanceboro
Thanks 67tponycoupe. It worked
poke68
Dec 16, 2025 03:36 PM
Sep 24, 2015 09:18 PM
Sep 18, 2015 12:25 PM
fastbackford351
Sep 12, 2015 09:42 AM
Sep 10, 2015 08:39 PM
