THIS SUCKS
Old Mar 29, 2006 | 09:15 PM
tylerdru's Avatar
tylerdru
Default THIS SUCKS
I got all of the brakes put on, and go figure my wheels dont fit. I am gonna run to the junkyard this weekend. What size rims will i need? backspacing and all?
EDIT: if anyone wants my rims i will sell them they are 68-69 rims i believe They are in pretty good shape.
Old Mar 29, 2006 | 09:16 PM
67Sally's Avatar
67Sally
Default RE: THIS SUCKS
Wow that does suck
Old Mar 29, 2006 | 09:20 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: tylerdru
Dennis told you the stock 14's won't fit. And, even with the Mag 500's you may need spacers.
slickman's Avatar
slickman
I'll bet you had 14 inch rims..
ORIGINAL: tylerdru
Old Mar 29, 2006 | 09:37 PM
tylerdru's Avatar
tylerdru
No i have 68-69 15x7 rims. the hub is too big for the wheel. (the big hole on the rim is too small) How much do you think i could get for these rims?
http://www.mustangsplus.com/Merchant...ory_Code=style
Old Mar 29, 2006 | 09:41 PM
slickman's Avatar
slickman
Not sure but, I would be a bit concerned that the hub is too big. I don't think going from drums to disk brakes would cause the hub to be larger.
Guys???
ORIGINAL: tylerdru
Old Mar 29, 2006 | 09:44 PM
tylerdru's Avatar
tylerdru
It is actually stated that original rims may be to small and the rotor may need to be machined to fit them.
Old Mar 29, 2006 | 09:46 PM
slickman's Avatar
slickman
I understand they would state that the rims maybe too small but they are normally talking about the inside dia of the rim in that it would rub on the caliper. The hub is normally not an issue, this is the first I have heard of it..
ORIGINAL: tylerdru
Old Mar 29, 2006 | 09:51 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
this a common problem with the granada conversion isnt it u have to machine down the hub?
Old Mar 29, 2006 | 09:55 PM
Soaring's Avatar
Soaring
I ♥ Acer
I've never heard of an issue with the hub being too big to fit. Call Dennis and tell him what you are facing.
