Yet ANOTHER tire sizing question...
Old Mar 31, 2006 | 01:43 AM
Craig67's Avatar
Craig67
Default Yet ANOTHER tire sizing question...
I'm gonna be getting tires for my 1967 Mustang. I want to get 15x7's, and some pretty nice tires to fit. I want some beefy, but not rediculous sized tires in the back, and smaller ones in the front. I'm keeping the stock bolt pattern, so what I'm asking is what size tires can I get that will fit 15x7's. Please help, I really have no idea what I'm talking about when it comes to tires.
Old Mar 31, 2006 | 02:03 AM
badazz68stang's Avatar
badazz68stang
Default RE: Yet ANOTHER tire sizing question...
get ya some hoosier racing slicks.
check the FAQ section, dodgestang has a pretty good chart that should help you out.
Old Mar 31, 2006 | 03:52 AM
Craig67's Avatar
Craig67
Okay, so I found these wheels and tires as a combination from the list in the FAQ. Do these look right for a stock application on a 1967 with drums all around?
http://store.summitracing.com/partde...D92737&FROM=MG
http://store.summitracing.com/partde...85764P&FROM=MG
Look good? I'm JUST BARELY starting to get a hang of this stuff...
Old Mar 31, 2006 | 04:25 AM
grocery getter's Avatar
grocery getter
I like the look of 16's or 17's
Old Mar 31, 2006 | 11:12 AM
dodgestang's Avatar
dodgestang
Rim is wrong backspacing.
Search engine is a valuable feature.
Old Mar 31, 2006 | 02:33 PM
Craig67's Avatar
Craig67
How can you tell what backspacing you need? And what is backspacing? On the chart that I looked at, it said that I needed 4.25in backspacing...
Old Mar 31, 2006 | 04:31 PM
Rorin67's Avatar
Rorin67
ORIGINAL: Craig67
BACKSPACING
Definition: The distance from the back edge of a wheel rim to the back of the center section.
It is VERY important, often overlooked, and WILL determine the way your wheels fit in the well and how wide of a tire you can have. Most mustangs require 4.5in backspacing for wider tires with a 7" or 8" wide rim. Here's an example - the prior owner of my 67 purchased Torque Thrust IIs with only 4" of backspacing in the front. 67s can usually take a decent width tire (usually up to 235 w/ 4.5in backspacing). However, since I have only 4" backspacing, the max width I can run in front without the tires rubbing to wheel well fender lip is 205. Any of this making sense?
Old Mar 31, 2006 | 05:28 PM
dodgestang's Avatar
dodgestang
My bad
Wheel, Soft 8, Steel, Chrome, 15 in. x 7 in., 6 x 4.5 in. Bolt Circle, 4.25 in. Backspace, Each
Read that this morning and though it was an 8 inch wheel.
Old Mar 31, 2006 | 10:28 PM
Craig67's Avatar
Craig67
Right. Okay I understand the backspacing. Basically if you don't have enough backspacing, the tire isn't going to go on far enough and the tire will be rubbing against the inside of the outer fender?
Also, what is getting your fenders rolled?
And now that you have looked at it again, do those specs for wheels/tires all around sound good?
Old Apr 1, 2006 | 01:23 PM
Craig67's Avatar
Craig67
Will a 16x8 rim fit on a stock 1967 with drums all around?
