1970 Mach 1
Old Mar 31, 2006 | 05:33 PM
jabba's Avatar
jabba
Default 1970 Mach 1
I have just purchased myself a 1970 Mach1 351v4. I have worked out that the engine is a cleveland. Can anybody tell me how I can work out if the engine is the original block fitted by the factory.
Old Mar 31, 2006 | 06:23 PM
Shifty101Easy's Avatar
Shifty101Easy
Default RE: 1970 Mach 1
casting numbers....check on the intake manifold or behind the starter on the block....it could be differnt though as i have a 302.......windsor block.....not a cleveland so i dono.....google where to look up the casting numbers for the clevelands.
Old Apr 1, 2006 | 12:07 AM
chillininnh's Avatar
chillininnh
Other than date coding the block to see if it was cast just previous to the build date on the car, I don't believe the blocks were stamped with any specific number corresponding it with a specific body. Generall speaking, if the date code is within the 2-3 months preceeding the build date of the car, it can be considered an original block. Hope this helps.
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
b8checker
Oct 8, 2015 12:55 PM
mustangheaven
Oct 7, 2015 10:23 AM
breaking
Oct 2, 2015 01:27 PM
b8checker
Sep 30, 2015 07:11 AM
