Loose shifter.
Old Apr 4, 2006 | 12:34 AM
Craig67's Avatar
Craig67
Default Loose shifter.
How do you tighten a shifter? Mine seems a little loose. Maybe that's just the way it is supposed to be, but it's worth asking you guys! When I lifted up the boot, there were 2 bolts holding it on (it looks like), and when I tried tightening those, no luck. They seem to be tightened all the way. Does this mean that I'm stuck with what I have until I get a new shifter?
Old Apr 4, 2006 | 12:38 AM
ngirg001's Avatar
ngirg001
Default RE: Loose shifter.
there is a d.i.y in the FAQs
Old Apr 4, 2006 | 12:39 AM
Soaring's Avatar
Soaring
I ♥ Acer
You can get a kit from just about any Mustang vendor that you can replace the worn parts. I messed around with mine for a few years by putting rubber from an inner tube between the parts, but finally gave up and replaced the worn parts.
mustanglover66's Avatar
mustanglover66
is it a auto or stick
Old Apr 4, 2006 | 12:41 AM
Craig67's Avatar
Craig67
Stick
ADDITION: I looked in the FAQ and couldn't find it. Maybe a link?
Old Apr 4, 2006 | 12:43 AM
mustanglover66
check the bushing on the linkage rods
Old Apr 4, 2006 | 12:45 AM
ideal_mustangs's Avatar
ideal_mustangs
Mine was like that too. I just ordered 2 new shifter bushings. I also had to order one new bolt. One of mine was stripped.
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: mustanglover66
Yeah, those two little round guys are the culprit, but the fork gets worn too. If you are going to bother with it, just replace the entire shifter stuff with a new kit.
Old Apr 4, 2006 | 12:50 AM
Cogtx's Avatar
Cogtx
Get you one of these kits and you should notice a world of difference. This was the 1st repair my son did on his inline 6 and made a noticable difference. Very easy to do...
http://johnsmustang.com/Catalog/725/
Old Apr 4, 2006 | 12:59 AM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: Cogtx
That's what I am talking about Danny. Plus, you can also get the shifter arm too. Otherwise the new kit may still not take out the buzz from the vibrations but it will certainly help.
