Question about my later model 302 block.
Old Apr 4, 2006 | 10:27 PM
tylerdru's Avatar
tylerdru
Default Question about my later model 302 block.
What flywheel do i need? How many teeth. And what about a flexplate?
I know i will need a 50 oz balancer.
Old Apr 4, 2006 | 10:37 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Question about my later model 302 block.
Is the 302 a 1986 or newer?
Old Apr 4, 2006 | 10:39 PM
tylerdru's Avatar
tylerdru
IT IS a 1986-1995 block
Old Apr 4, 2006 | 11:02 PM
Soaring's Avatar
Soaring
I ♥ Acer
I am not real familiar with the EFI 302's with their computer system, oxygen sensors and EGR valves. If you are conveting that EFI engine to a carbureted version here is some reading. http://www.fast351.com/tech/fitocarb.htm
Old Apr 4, 2006 | 11:11 PM
tylerdru's Avatar
tylerdru
It is just the block so i wont be dealing with any electronics. I could just use a normal 302 mechanical fuel pump right?
Old Apr 4, 2006 | 11:24 PM
Soaring's Avatar
Soaring
I ♥ Acer
Yep, and 57 tooth.
Old Apr 4, 2006 | 11:27 PM
66 Hardtop 5.0's Avatar
66 Hardtop 5.0
If you use a mechanical fuel pump (and thats my advice), you need to mount an excentric wheel on the end of the camshaft to operate the pump. Any 289cid excentric wheel is a direct fit, but you need a longer stud going through the excentric wheel to prevent it from rotating.
Old Apr 4, 2006 | 11:30 PM
tylerdru's Avatar
tylerdru
Hmm what if i just bought an electric pump?
Old Apr 4, 2006 | 11:40 PM
tylerdru's Avatar
tylerdru
Where can i get a longer stud? i have the ecentric on my 289 already.
Old Apr 4, 2006 | 11:43 PM
351foxstang's Avatar
351foxstang
ORIGINAL: tylerdru
i would think you could re-use the one that was on your 289, but i may be wrong.
