How To Remove Window Regulator???
Old Apr 8, 2006 | 08:13 PM
Shifty101Easy's Avatar
Shifty101Easy
Default How To Remove Window Regulator???
anyone have a clue how to get the regulator rollers off the track so i can take it out?????ive tried unscrewing like every bolt and jiggling ot for like an hour and it just dosent come off.....there is zero documentation and absolutely no one who cares these parts seems to know.
Old Apr 8, 2006 | 08:29 PM
Smothers's Avatar
Smothers
Default RE: How To Remove Window Regulator???
I use to replace auto glass for a living. Its been awhile and I cant recall what the mustang setup looks like, but ill try to help. Im guessing from your post you are not wanting to remove the regulator, just the glass and the track that attatches to it. Is there a slot in the portion of the track that the rollers are in? If so try this: Loosen the front and rear channel guides if possible. Then roll the window up and or down untill one of the rollers lines up with the slot in the track (if there is a slot). You should be able to pull that roller out of the track through the slot. Then allow one end of the glass/track (I think it will be the front end) to dip down inside the door allowing you to slide the remaining roller out of the end of the track (it is possible there is a small flange in the end of the track that will need to be bent down (like with pliers) to allow the roller to come all the way out of it). The glass and track should then be freed up. You might want to take the felt/chrome pieces that are at the inside top off of the door to give more room. If you do this, be very careful not to break off the little metal tabs that allow it to attatch to the door. They will probably be a little rusty and brittle.
If this doesnt work, Maybe you can describe what you see in there and I can respond to it. Pics would help. Like I said, its been awhile since Ive had one apart.
Good luck
Old Apr 8, 2006 | 08:33 PM
Smothers's Avatar
Smothers
Duh, now I see the title of you post. So you do want the regulator out. Obviousle you want to get the glass and track out first to make it easier.
Old Apr 8, 2006 | 09:57 PM
Shifty101Easy
yeah, i just want to replace the regulator because i can push my window down right now....it rolls up and stays up but i can push it down and that dosent seem correct so i just bought a new regulator to fix it...what a bad idea that was... lol
Old Apr 8, 2006 | 11:56 PM
Smothers's Avatar
Smothers
I think its a good idea. I still think you want to take the door glass out to put the regulater in. I can't recall if that regulator bolts in or if rivets are used. Im sure you took notice of that. Have you figured out how to make the switch yet?
BTW you will want to use a dab of grease inside the track to allow the rollers to slide/roll more easily. Friction is usually the blame for regulator failure. I would dab some grease on the reg. too.
Old Apr 9, 2006 | 01:48 AM
Cogtx's Avatar
Cogtx
Don't know what year model you have but we have replaced window regulator on my son's 67 coupe w/o much prob. There were 3 phillip head screws connecting the botton of the glass to the regulator. Removed the screws and unbolt the rest of the old regulator. The window didn't have to come out just make sure someone holds it or tape it up to keep it from falling into the door. Here is a link... http://www.mustangandfords.com/howto/5151/index.html
Hope this helps....
Old Apr 9, 2006 | 04:46 AM
Shifty101Easy
yeah alright, i just went out there to take a look and all three friggin screws are stripped to hell!!! im so distraught right now......i dont know what to do....those suckers are in there pretty good....someone must have sabatoged them before....
so what do you suggest i do???? if i could get these off i can see the regulator would come out really easily....but thats only if i can get these out......
Old Apr 9, 2006 | 06:17 AM
ngirg001's Avatar
ngirg001
can you take a picture of which screws to take off? im planning on doing this for my ride and since there isn't much info i bet you could create a good DIY for future people
Old Apr 9, 2006 | 02:54 PM
Soaring's Avatar
Soaring
I ♥ Acer
Can you reach the screws with a drill? I have a drill head that is in an "L" shape for those tight spots. Drill out the screws, tap the hole, then put in new screws after replacing the regulator.
Old Apr 9, 2006 | 05:06 PM
Shifty101Easy
yeah i think i can get to at least 2 of the 3.....im positive about the middle one......id have to go buy a tap though.....do u know which size drill bit and tap i should use?????? and when you say drill the screws out do u mean get a bit thats bigger than the screw and the hole and just completely obliterate it all and then tap new threads??? i dont know if a tap will make it all the back there on some of the holes....im going to go take some pictures.....
