Block ID confusion
Old Apr 8, 2006 | 11:51 PM
bignatesan's Avatar
bignatesan
Default Block ID confusion
Hello everyone. I am a new owner of a 1966 coupe in OK shape, at least it made the 3 hr drive from Vallejo to Montery with no problems. Anyway, it originally had a 6 cyl. based on the door number. It now has a V8 under the hood with a 2V carb. The casting number off the block is C9OE-6105-C. I have looked all over to see what block this is with no luck. I am sure of the number and took a picture of it as many posts I found with a similar question thought the person posting it was confused. It appears all necessary modifications were done when adding the new engine (front end, mounts, brakes, 5 lug, etc.). If anyone can point me in the right direction to find out what block this is, that would rock!
Nate
[IMG]local://upfiles/34051/9B03EB96F52247849BBAF6BD6B62D7BF.jpg[/IMG]
Old Apr 9, 2006 | 02:28 AM
serge627's Avatar
serge627
Default RE: Block ID confusion
Looks like its a 69 302 4bbl out of a torino or fairlane.
use this site here...
http://www.themustangshop.com/index..../resources.cfm
Hope it helps
Edit: Ok heres another site
http://www.classicmustang.com/decoding_part_numbers.htm
Old Apr 9, 2006 | 03:25 AM
bignatesan's Avatar
bignatesan
Thanks, that helps. Just about every other C9OE - (B, C, H) was showing up as a 351W, just couldn't get a hit anywhere on C9OE-C except for a parts catalog from this site http://beckracing.com/slvpg49.htm shows it as a 351W casting. The water pump mount is flush with the head so it makes sense that it is a 302 ( I would asume the 351W would be higher since the higher deck). It has a 2v mounted on a 289 manifold with a enigine tag that says it is a 289, obviously not accurate. I will probably match it up over time with a 4v and a better intake manifold, no rush though as it runs smooth as silk right now. Thanks again!
Nate
Old Apr 9, 2006 | 01:09 PM
serge627's Avatar
serge627
No problem, it looks like the car is in very good shape from the picture you posted!!
Old Apr 9, 2006 | 01:21 PM
bignatesan's Avatar
bignatesan
It is, I just picked it up for 4k in Vallejo CA. The cowl is leaking though so I just slapped a cowl cover on until I have time to fix it. Has some rust on the A pillar and bottom of L front fender and the paint is fairly ametur but not terrible. Floor boards have been patced, but done pretty poorly. Pretty happy with the total package even with it being a frankenstien of various years.
Nate
Old Apr 9, 2006 | 02:27 PM
Soaring's Avatar
Soaring
I ♥ Acer
Looks to be a pretty nice ride for 4K.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
marc954
Sep 29, 2015 03:05 PM
mustangheaven
Sep 29, 2015 11:00 AM
mrappe
Sep 26, 2015 10:16 AM
marc954
Sep 25, 2015 06:48 AM
