Carb Question
Old Apr 11, 2006 | 03:17 PM
DrBob67's Avatar
DrBob67
Default Carb Question
I'm putting back together my 67 289 engine after head gasket blew due to a freeze plug that sprung a leak. It has been sitting for a few years and I'm finally getting to it. The head gasket went bad between cylinders 5 and 6. So there was no mixing of the oil and coolant. Had the heads and valves machined and converted for unleaded gas. I have not done any modifications to the bottom part of the engine such as cam, so it is basically stock. I did pull off the oil pan and there wasn't much crud in the bottom and I replaced the oil pan gaskets. I had put in a rebuilt engine a few thousand miles before the head gasket went. The only other things I've done is get a pertronix electronic ingnition conversion and converted it to dual exhaust with regular exaust manifolds no headers.
This is the question I bought a new intake manifold edelbrock 2121 see below. and a edelbrock carb 1403 500cfm (see below) and a circular air filter housing for the top of the carb (not sure if that is the right name). I have not put them on yet. A friend of mine has a new in the box edelbrock carb # 1407 (see below) with 750 cfm that he wants to sell me. When I spoke to someone from edelbrock they said that the 1407 with 750 cfm is too much carb for my engine and it would be a problem.
Does anyone have any experience or opinion about using the 1407 carb or other advice? I just signed up for the forum yesterday and I'm hoping some of my stang brethren can help me out. Also I ordered the book How to Rebuild Small-Block Ford Engines that someone else on the forum recomended and bought a timing light on ebay.
The coolant fluid looked pretty good and I did not check yet to see if my gas tank has a drain. So I'm not sure if I need to drain the gas tank, I do have a new fuel filter.
Bob Johnson
San Diego, CA
Edelbrock Intake Manifod Part #2121
Ford 260-289-302 V8
PERFORMER 289 (idle-5500 rpm)
Designed for street 260-289-302 c.i.d. Ford V8s without EGR. #2121 is stock replacement/street legal part for 289 and 302 V8s with OEM 4V carb.; 1966-72 (1973 non-CA); except stock equipped EGR. Will not fit Boss 302 or 255 c.i.d. V8s. Aftermarket 4-bbl carbs are not compatible with Ford Auto Overdrive Transmission (AOD) unless used with Lokar bracket SRK-4000. Available with standard finish, polished or with PermaStar or new EnduraShine finish for a look you've got to see to believe, see Optional Finishes.
Edelbrock Carb part # 1403
500 cfm, Manual or Electric Choke
CALIBRATED FOR PERFORMANCE
Designed and calibrated for small cubic-inch engines such as 305 c.i.d and smaller Chevrolet; 302 c.i.d. and smaller Ford and dual-quad applications such as Edelbrock C-26, F-28 and Street Tunnel Ram. Match with an Edelbrock Performer or Performer EPS manifold and other brands of similar design. Includes both timed and full vacuum ports for ignition advance. Comes with: Metering Jets – Primary .086, Secondary .095; Metering Rods – .065 x .052; Step-Up Spring – orange (5" Hg). Use Carb Studs #8008 or #8024 if needed, see Install Items. For auto trans throttle lever adapters and more, see Tuning Accessories.
Edelbrock Carb part #1407 750 cfm, Manual Choke
Designed and calibrated for optimum street performance in small-block and big-block engines with Performer RPM, RPM Air-Gap and Torker II manifolds and with Performer manifolds on large cubic-inch engines. Includes both timed and full vacuum ports for ignition advance. Electric choke #1478 can be added if needed. Comes with: Metering Jets – Primary .113, Secondary .107; Metering Rods – .071 x .047; Step-Up Spring – orange (5" Hg). Use our Carb Stud Kits #8008 or #8024 if needed, see Installation Items. For auto trans throttle lever adapters and more, see Tuning Accessories.
750 cfm, square-flange, manual choke (non-EGR)
Old Apr 11, 2006 | 03:49 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Carb Question
Hey, Doc Bob... Welcome to the classic section of MF. Yeah, with a stock 289, you won't need any more than the 500 CFM carburetor. The guys who advised you are right. 650 is way too much carb. The Motorcraft 4100 4V carb that Ford put on their stock V8 A Code cars was only 470 CFM.
Old Apr 11, 2006 | 05:47 PM
michaeldoggrell's Avatar
michaeldoggrell
I replaced my 2V manifold with a 4V manifold and put an Edlebrock 600FM on there. Works great !
Old Apr 11, 2006 | 06:38 PM
Soaring's Avatar
Soaring
I ♥ Acer
Sure it does, but can you get just as good or better performance from a carb that is designed for your engine? I think so....
GimpyHSHS
19
Dec 19, 2023 01:12 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
UrS4
Sep 30, 2015 10:13 AM
treesloth
Sep 28, 2015 07:03 AM
