Sagging Doors
Old Apr 13, 2006 | 03:33 PM
badazz68stang's Avatar
badazz68stang
Default Sagging Doors
In order to shut my driver side door you have to pick up on it a little bit and it is hard to shut from on the inside sitting down. could this just be doorhinges, any suggestions.
Old Apr 13, 2006 | 03:51 PM
rwh129's Avatar
rwh129
Default RE: Sagging Doors
Most older car doors will sag with age.
Was it hit ?
Your probably right about the hinges.
Try this link. It helped me.
http://www.theclassiccougarnetwork.com/tccn/framex.html
Old Apr 13, 2006 | 03:55 PM
rwh129's Avatar
rwh129
Link did not work.
Use the link then click on magazine, then click on shop talk articles, then repairing droop doors
Old Apr 13, 2006 | 04:34 PM
Soaring's Avatar
Soaring
I ♥ Acer
Sounds like the hinges need some work. Replace the pins. Here is a pretty comprehensive article explaining how to do that.
http://www.mustangandfords.com/howto...d_door_hinges/
Old Apr 13, 2006 | 04:35 PM
ngirg001's Avatar
ngirg001
ok mine dont sag but the driver one is higher than normal. what should i do about that?
Old Apr 13, 2006 | 05:16 PM
Soaring's Avatar
Soaring
I ♥ Acer
Loosen the hinge bolts on the post slightly and re-align it, then tighten the hinge bolts.
jerrytubes
Oct 23, 2015 12:11 PM
jrrhd73must
Oct 2, 2015 09:17 PM
breaking
Oct 2, 2015 01:27 PM
Sixer4Life
Sep 29, 2015 07:03 PM
Sep 25, 2015 06:58 PM
