Brake line help
Old Apr 17, 2006 | 09:52 PM
tylerdru's Avatar
tylerdru
Default Brake line help
Hey guys,
Should i have a granada distribution block? I do have a proportioning valve. Right now i need to get the MC in and the lines hooked up right.
Old Apr 17, 2006 | 11:36 PM
popper's Avatar
popper
Default RE: Brake line help
No, just use the distribution block you already have.
Old Apr 18, 2006 | 03:52 AM
67t5ponycoupe's Avatar
67t5ponycoupe
If you are going from drum-drum to disc-drum you need a proportioning valve not a distro block. Finding a good Granada one might be a trick. The one I tried to use was seized up and ended up going with and after market one from master power brakes. (mpbrakes.com)
Old Apr 18, 2006 | 11:42 AM
popper's Avatar
popper
Tyler, you need both. See Dennis' procedure: http://www.discbrakeswap.com/The_Gra...9.3006.v01.pdf
See page 15
Use your stock DB and the prop valve that came with the kit.
Old Apr 18, 2006 | 01:48 PM
67t5ponycoupe
Ok lets be clear about that we are talking about. If you have a stock mustang distro black you can use that with an adjustabe proportioning valve. If want to use the granada style proportioning valve then you do not need the distro block or the adjustable proportioning valve.
Old Apr 18, 2006 | 04:35 PM
tylerdru's Avatar
tylerdru
Okay, i do have the proportioning valve. It is just that the MC threads for the lines and proportioning valve inlets are different sizes. The mc is a little bit bigger.
Old Apr 18, 2006 | 05:25 PM
degins's Avatar
degins
ORIGINAL: 67t5ponycoupe
Correct, both counts.
Old Apr 18, 2006 | 05:26 PM
degins's Avatar
degins
ORIGINAL: tylerdru
Use an adapter at the MC.
Old Apr 18, 2006 | 06:09 PM
tylerdru's Avatar
tylerdru
I walked into autozone and asked for such an adapter and they said that it did not exist. I was pretty sure something like that did. what size are the inlets on my granada MC?
Old Apr 19, 2006 | 04:02 AM
67t5ponycoupe
You guys really need to get out of the habit of using those crappy parts stores. I know they have their pupose but if you need something like a brake line adapter you need to go to a place like Carquest, Worldwide or god forbid NAPA. You may have to get the correct size fitting, cut the line, remove the old fitting, install the new fitting and then reflare the line.
