Need POWER for cd player!??
Old Apr 18, 2006 | 08:07 PM
19stang66's Avatar
19stang66
Default Need POWER for cd player!??
I am installing a Kenwood EZ500 soon, havent bought it yet, and I got around to running the wiring for the rear 6x9's and the front 6 1/2's. Now I am wondering on how to get power from the battery to the fuse box to the deck. I don't really know how to explain it that well.
How would I run power from the fuse box to the headunit? So when I turn on the ignition, the cd player turns on, like in newer cars. Is it possible with the factory fuse box? Or do I need to buy something else?
Also, how did you guys with modern cd players in your dash secure them in place?
Old Apr 18, 2006 | 08:14 PM
atomsk680's Avatar
atomsk680
Default RE: Need POWER for cd player!??
im not sure about the power, but you can get a mount for the cd player to hide it under the dash
mayh3m's Avatar
mayh3m
cd players have 2 wires that do this for you. one will be hooked up to a constant 12v power source. another will be hooked up to an ignition wire which actually turns the radio on. it's pretty simple.
Old Apr 18, 2006 | 08:18 PM
19stang66's Avatar
19stang66
So the constant 12v power source is the battery and i'll need to splice into the orange ignition wire or a different one?
I dont have to go through the fuse box then?
Old Apr 18, 2006 | 09:09 PM
dcohen's Avatar
dcohen
id just put an in-line fuse in it and not worry about going through the fusebox
Old Apr 18, 2006 | 10:17 PM
Riven02's Avatar
Riven02
I spliced into the fuse box. I am working from memory here but I beleive I used the ACCY fuse (Top fuse in the box)for the ACCY input and the Cig Lighter (Bottom Fuse in the box) for the constant.
Old Apr 18, 2006 | 10:21 PM
Riven02's Avatar
Riven02
The reason I did not splice into the Ignition wire was because I did not want to cut and factory wires. I wanted to be sure if I wanted I could remove the cd player and no one would ever know it had been there.
The securing method would depend on where you are mounting it. I put mine in the glove box. I have a picture of it in my gallery.
Old Apr 18, 2006 | 10:38 PM
Yoruai's Avatar
Yoruai
Not necissary to use the fusebox no. With my alpine I just ran the constant straight to the battery and used an inline fuse. As for the ignition wire it took me some trial and error with a multimeter due to earlyer non standard rewireing of the dash. Make sure you use an inline fuse though and a heat resetant wrap or conduit on the wires to tha battery, it gets hot under the hood.
You might laugh but to put it into the dash I just cut teh plastic to fit and screwed the breaklight indicator behind it under the dash to keep it from slipping back. I don't need that thing to tell me I'm breaking. hasent ever fallen out or skipped!
jwog666
Dec 27, 2021 08:09 PM
jrrhd73must
Oct 2, 2015 09:17 PM
KingRando
Oct 2, 2015 08:06 AM
Sep 25, 2015 06:58 PM
