driveshaft removal
Old Apr 18, 2006 | 10:50 PM
coupe67's Avatar
coupe67
Default driveshaft removal
whats the best way to remove the driveshaft? 68' fastback 4 speed thanks.
Old Apr 18, 2006 | 10:57 PM
mustanglover66's Avatar
mustanglover66
Default RE: driveshaft removal
unbolt the u bolts at the rear gear , the shaft will drop down from there, Than pull it out of the back of the trans.
Old Apr 18, 2006 | 11:06 PM
Yoruai's Avatar
Yoruai
Make sure you jack up the car from the rear to avoid tranny fluid spilling out once the slip yoke is removed.
Old Apr 18, 2006 | 11:07 PM
acidrain088's Avatar
acidrain088
drain the gear oil from the tranny or it will fall on you when your under there and it smells really bad trust me its different than any bad smell you have delt with before.
Old Apr 18, 2006 | 11:10 PM
ttoney's Avatar
ttoney
Jack the car up and have a large plug of Seran Wrap etc. ready to plug the opening in the tailshaft.
Old Apr 19, 2006 | 01:13 AM
351foxstang's Avatar
351foxstang
ORIGINAL: acidrain088
i taped a plastic bag over the end of mine to remove it.
have you ever tasted it? [:'(] taught me not to pull a transfer case out of a truck while being directly under it.
good luck
jwog666
Dec 27, 2021 08:09 PM
baddog671
Jul 26, 2016 01:20 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
Dathan
Oct 5, 2015 05:52 AM
jrrhd73must
Oct 2, 2015 09:17 PM
