67 Floorboards
Old Apr 20, 2006 | 11:45 PM
timbrigham's Avatar
timbrigham
Default 67 Floorboards
I recently acquired a 67 Mustang convertible which has some minor body damage (mainly a few rust spots), but the floorboard on the driver's side is rusted through. I've also acquired a replacement floorboard. However, I'm not sure what all I need to do to to pull it out. Some instruction would be appreciated.
Old Apr 21, 2006 | 12:05 AM
dcohen's Avatar
dcohen
Default RE: 67 Floorboards
get a spotweld cutter, a good air powered disk cutter, and if youve got enough money a plasma cutter, then just start cuttin little chunks out, cut most of it out with the disk cutter and then use the spotweld cutter to get the welds loose
Old Apr 21, 2006 | 12:15 AM
ideal_mustangs's Avatar
ideal_mustangs
http://mustangmonthly.com/howto/mump_0411_pan_replace/
Old Apr 21, 2006 | 01:25 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
make sure u dont cut thru ur brake lines or thru the gas line should remove it all together!
kirk35
Aug 17, 2015 08:42 PM
damquick1
Jan 15, 2007 02:36 PM
Texas
Dec 13, 2006 02:11 PM
69 Convertible Stang
Nov 10, 2006 03:53 PM
Ck9887
Dec 1, 2005 09:57 PM
