driveshaft help quick!
Old Apr 21, 2006 | 08:29 PM
aj05must's Avatar
aj05must
Default driveshaft help quick!
so im installing a t5 in my 65 that originally had a c4. now im having a little confusion on how much my driveshaft needs to be shortened. i purchased the transimission from modern driveline and was told that it needed to be shortened about 3/4 of an inch. i need to make sure that that is absolutley correct because im about to leave for the shop and would definetly not want to have the wrong measurement.
also, i am having new u joints put on but what about the slip yoke? should it be ok or should i hve it replaced??
Old Apr 21, 2006 | 08:30 PM
aj05must's Avatar
aj05must
Default RE: driveshaft help quick!
oh and i forgot i measured my driveshaft from center of u joint to center of u joint and it came out to be 50 and 7/8 inches
Old Apr 22, 2006 | 01:33 AM
ttoney's Avatar
ttoney
Call the place that is going to mod you driveshaft. They will tell you where they want you to measure. Sould be from the end of the tailshaft to the inside of the u-joint. They will make it the correct length.
Have them look at the slip yoke and u-joints, they will tell you what needs replaced.
baddog671
Jul 26, 2016 01:20 PM
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
