when i drive to school...
Old Apr 22, 2006 | 01:00 PM
Littlepepe27's Avatar
Littlepepe27
Default when i drive to school...
-Hi when i drive to school after maybe 8-10 blocks i feel alot of heat coming from under the dash why is that?
Old Apr 22, 2006 | 02:34 PM
BillyBobJoe's Avatar
BillyBobJoe
Default RE: when i drive to school...
my guess is that you have a leak in the exhaust near there, or that your firewall insulation needs to be replaced, or that there is a hole in the firewall that causes hot air from the engine bay to leak into the car...try taking a peak under the dash for holes check the insulation
Old Apr 22, 2006 | 02:50 PM
Clu7ch's Avatar
Clu7ch
yeah, i had a hole under the dash on the drivers side prolly about 1 inch across. someone had covered it with duct tape, but it had started falling off again. i have reason to believe this is from the clutch petal, but someone told me even the auto ones have this hole.
Old Apr 22, 2006 | 03:01 PM
Littlepepe27
ok thanks guys...i have to go to work right now, but when i get back ill check it out for sure...thanks again
Old Apr 22, 2006 | 03:42 PM
Littlepepe27
another quick question...is it a hassle to replace?
Old Apr 22, 2006 | 04:00 PM
67t5ponycoupe's Avatar
67t5ponycoupe
Check your heater controls and make sure they are operational and that the flappers are in the right position. You may be getting heat out of the heater.
Old Apr 22, 2006 | 04:38 PM
Dan66Stang's Avatar
Dan66Stang
I have the same thing, its a hole for the clutch. Well mines a auto now but the hole is still there. Ive tried covering it up but everything always fails. Anyone have any clever ideas?
Old Apr 22, 2006 | 05:01 PM
dcohen's Avatar
dcohen
well, if it were me i'd take a short bolt and two big fenderwashers with some rubber behind the fender washers and put the bolt through the hole so that the fender washers would seal the hole up, then just tighten the bolt and that should do it, if you want to make SURE that it stays put then just put some lock-tight on the bolt
Old Apr 22, 2006 | 05:06 PM
Soaring's Avatar
Soaring
I ♥ Acer
In the redneck world, we would just put some duct tape over the hole, then hit it with a big glob of roofing tar. Seriously though, you can buy a new firewall insulation kit. The holes are almost cut through the insulation, but not quite. A good spray of black sound proofing ove it would seal it. Also, I agree that the heat may be coming from your heater box too. Make sure the heater is turned off. Also, if it is hot out, and you have air conditioning, make sure the cowl vent is closed.
Old Apr 22, 2006 | 05:13 PM
Shifty101Easy's Avatar
Shifty101Easy
ORIGINAL: Soaring
hahahaha.
check the heater......i bet its that......
if not, shine light through the engine bay and turn off the garage lights to see if theres any light shining through open holes.
