Cowl leak repair
Old Apr 23, 2006 | 04:47 PM
slickman's Avatar
slickman
Default Cowl leak repair
Well, I got the driver and passenger side apart yesterday and it was not as bad as I expected Both the driver and passenger side had some rust holes along the seams near the top hat area and in the corners. The top hat on the passenger side was fine but the driver side top hat had holes around half of it were it meets the cowl. The passenger side was an easy repair with some silicone, POR15 and the top hat for good measure.
The driver side needed a bit more work with the damage around base of the top hat. So, I used POR15, silicone and the new plastic top hat. So, all the holes and seams are coated with POR15 and silicone. The new plastic top hats are glued in place with the driver side air vent bolted back on.
I'm waiting for a new heater core to come that I ordered (may as well replace it) and then I'll put that heater box back in and that should be it. I feel this will take care of the leaks for a long time.. Thankfully the problem was no way as bad as what I have heard about like needing to replace the entire metal because it was totally rotted away..
Other than that, the entire cowl was soild!!
Old Apr 23, 2006 | 05:10 PM
usmcdevilmp's Avatar
usmcdevilmp
Default RE: Cowl leak repair
good to hear you were lucky on the work you didnt have to do. that stuff can be a pain in the butt. you didnt take any pictures, did you? if so would you like to share?
Old Apr 23, 2006 | 07:09 PM
slickman's Avatar
slickman
Nope, did not take any pics, not much to see. I tried taking some pics last night but, I could not get them to focus
Old Apr 23, 2006 | 07:31 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: slickman
Yeah, it's kinda hard to take good pics while you are standing on your head, huh? Glad it is coming together Slick.
Old Apr 23, 2006 | 08:02 PM
slickman's Avatar
slickman
Thanks Soaring.. Should be done in a few days and next week I'll give it a bath and see if she satys dry..
ORIGINAL: Soaring
ORIGINAL: slickman
bradleyb
Nov 27, 2015 07:50 PM
jerrytubes
Oct 23, 2015 12:11 PM
b8checker
Oct 8, 2015 12:55 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
b8checker
Sep 30, 2015 07:11 AM
