Electric Fans
Old Apr 23, 2006 | 05:27 PM
usmcdevilmp's Avatar
usmcdevilmp
Default Electric Fans
What electric fans are you running in your car? I was thinking about Flex a lites #150 in my 66. Thanks.
Old Apr 23, 2006 | 06:57 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Electric Fans
There are electric fans, and then there electric fans. First, why do you think you need an electric fan? Second, what setup do you have?
Old Apr 23, 2006 | 07:03 PM
usmcdevilmp
ORIGINAL: Soaring
I dont have a electric fan setup right now. i will have a 347, performer RPM package, stock radiator, pullies. I want a electrical fan for the HP reasons. It will be a daily driver and i will be in hot weather. i dont want a fan shroud around the mechanical fan.
Old Apr 23, 2006 | 07:36 PM
Soaring's Avatar
Soaring
I ♥ Acer
You are going to have a shroud around an electrical fan, so why not have one around the stock fan? Understand, that you will save a few ponies with an electrical fan, but you will also be taxing the alternator, therefore drawing more HP. Have you thought about upgrading your alternator to something besides the 70 amp stock alternator? Anyway, the fan you have chosen is a proven and reliable electric fan. http://www.flex-a-lite.com/auto/html/ford-mustang.html
Old Apr 23, 2006 | 07:44 PM
usmcdevilmp
I know ill have the shoud with that fan and thats ok. i just didnt want the big stocker. I will be upgrading my alternator also. Thanks for the input.
Old Apr 23, 2006 | 07:49 PM
Soaring's Avatar
Soaring
I ♥ Acer
Then, I think you will need the flexlite #475. Call them before you leap. BTW, the 66 Mustang did not have a stock shroud from the factory. I put on an aftermarket one on my 65, and it is not the gross plastic thing that covers half the engine bay as on newer models.
Old Apr 23, 2006 | 10:35 PM
Clu7ch's Avatar
Clu7ch
i was going to say the same thing. my 66 doesnt have one and i almost forgot one day.
so, when going for an electric fan, upgrade the alt. check. anything else important to know whit ele fans?
Old Apr 23, 2006 | 10:52 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: Crash
Decide on whether you want a push or a pull fan.
Old Apr 26, 2006 | 12:40 AM
fast66's Avatar
fast66
ORIGINAL: Soaring
My 66 came with a stock shroud. Its a metal one, that is definietly stock. It doesnt seal too well around the radiator, however it is there. Maybe A/C fitted cars had them?
Old Apr 26, 2006 | 02:42 AM
Iskwezm's Avatar
Iskwezm
i have 2 16" fans, one pusher and one puller
