HEI style distributor
Old Apr 23, 2006 | 09:12 PM
usmcdevilmp's Avatar
usmcdevilmp
Default HEI style distributor
has anyone installed a HEI style distributor from DUI or Pertronix? Do you like or dislike? Please no comments if you havent done it. Thanks.
Old Apr 23, 2006 | 11:47 PM
67t5ponycoupe's Avatar
67t5ponycoupe
Default RE: HEI style distributor
Put an Summit brand HEI in my 67 and I like it except I ran into clearance problems with the heater fitting on the manifold and the air cleaner.
Old Apr 24, 2006 | 02:57 AM
usmcdevilmp
ORIGINAL: 67t5ponycoupe
What kind of manifold, carb and air cleaner are you using? what did you do about the clearance problem?
Old Apr 24, 2006 | 02:09 PM
67t5ponycoupe
Using a Wieand Sleath, a holley 570 and a 14 inch K&N. I had to go to an 11 inch K&N and I'm not real happy with it. It looks too small. For the heater hose connection I had to usde a straght nipple and get a hose with a pre bent 90.
Old Apr 25, 2006 | 02:51 AM
usmcdevilmp
do you think you could get a pic if its possible? how do you like the distributor besides the other stuff?
Old Apr 25, 2006 | 04:37 AM
67t5ponycoupe
Here are some pic's. This is with the 14 inch air cleaner and a 3/4 inch spacer to raise the air cleaner. It was all going to work like that until I put the hood on. Not even close to clearing the hood. Dizzy seems to work good. It has a vacuum advance on it that I haven't got dialed in yet. I haven't driven the car since I got it running except to take it for alignment. I'm on the body now.
[IMG]local://upfiles/27838/AA1DCFC297AD48E188C9183DF292DA13.jpg[/IMG]
[IMG]local://upfiles/27838/A83752087C8C45FA8BB191468EC3E763.jpg[/IMG]
Old Apr 25, 2006 | 04:58 AM
usmcdevilmp
thanks for the pics. maybe ill try the spacer when i get a HEI. i will have a cowl hood on so no prob there.
Old Apr 25, 2006 | 05:09 AM
67t5ponycoupe
Hey that should work good for you. If clearance on the hood is not an issue go with a one inch spacer. The 3/4 was a little tight on the dizzy. If could have been higher.
bradleyb
Nov 27, 2015 07:50 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
StalkerGT
Sep 25, 2015 02:41 PM
dalehunter
Sep 25, 2015 10:51 AM
jaiidutch
Sep 14, 2015 10:29 AM
