removing carpet
Old Apr 23, 2006 | 11:47 PM
Clu7ch's Avatar
Clu7ch
Default removing carpet
is there a trick to this or just grab and yank? i'm trying to remove the int and start working on the floorboards but the carpeting is a b!tch to get out! and pointers?
Old Apr 23, 2006 | 11:48 PM
ideal_mustangs's Avatar
ideal_mustangs
Default RE: removing carpet
Remove all the trim and interior pieces that could be holding it down. There are also 2 screws under the front seats. After that, it should just lift right out.
Old Apr 23, 2006 | 11:59 PM
Clu7ch's Avatar
Clu7ch
so far it seems as if someone lined the floor boards with spray adhesive before puttin in the carpet. i don't know if it has ever been replaced. i'm just trying to save a bit of time in pulling it all out.
Old Apr 24, 2006 | 12:02 AM
6mustang6's Avatar
6mustang6
yeah, you should be able to tear it out, with everything else removed.
Old Apr 24, 2006 | 12:10 AM
Soaring's Avatar
Soaring
I ♥ Acer
It should go without saying, but the seats and all chrome interior trim as well as the kick panels need to be removed. Spray adhesive huh? You can just rip and tear. That spray adhesive is not that strong. It is also easier if you remove the tranny shifter. And, if you have a console, that will also need to be removed. Just common sense stuff.
mustanglover66's Avatar
mustanglover66
try dumping some thinner on it
Old Apr 24, 2006 | 12:59 AM
Clu7ch's Avatar
Clu7ch
i started from the back and it comes up but i need to pull hard. maybe i'm just too weak. i guess i should try eating more veggies and less fast food, maybe hit the gym here and there. well, i guess i try some more tomorrow. i haven't touched it in a few months, tired of getting all excited and not having money to do anything, but after i pay my ticket tom morn, it'll be the only thing to keep me calm!
Old Apr 25, 2006 | 02:54 PM
casaleenie's Avatar
casaleenie
I'm not having a problem removing carpeting but rather getting it to stay in place... GT 04 Vert and when I slide inti the drivers seat the carpeting also slides towards the front of the car.. I kick it back in place with my heel but I don't see that as a long term solution... Also, the carpeting seems a very inferior quality... The car only has 1500 miles on it so the carpet is essentially new... I'd be up to replacing it with a higher quality carpet if necessary....
Old Apr 25, 2006 | 06:20 PM
67Sally's Avatar
67Sally
ORIGINAL: Crash
I couldnt have said it any better
Old Apr 25, 2006 | 07:29 PM
Soaring's Avatar
Soaring
I ♥ Acer
Give these members a call to help you. I bet they could have it out in a nano second.
