removing carpet
Old Apr 26, 2006 | 01:44 AM
Clu7ch's Avatar
Clu7ch
Default RE: removing carpet
backyard mech's do it best!
Old Apr 26, 2006 | 02:27 AM
ngirg001's Avatar
ngirg001
my old carpet smelled so i just took out the seats and ripped that crap out. replaced it with some fresh carpet with no problems. when in doubt rip it out. jk dont follow that LoL
Old Apr 26, 2006 | 04:27 AM
MidNite27's Avatar
MidNite27
I have new carpet i need to install, how long on average is the removal and install process?
Old Apr 26, 2006 | 10:56 AM
padgecomm's Avatar
padgecomm
I'm in the process now. I would sit aside 4 or 5 hours, maybe more if you need cleaning underneath.
My carpet didn't fit exactly as I wanted, had to trim some places and folds.
Old Apr 26, 2006 | 03:02 PM
Clu7ch's Avatar
Clu7ch
i just need it out so i can get to the floor boards and see what kind of shape they are in. i know i'm looking at alittle rust an dfigured the inside would be th ebest place to start. the way my knees feel right now, it' may be a while before i get to touch it. damn surgery. i shoulda done it when i was 16 and just got it taken care of!!!
Old May 20, 2006 | 10:25 PM
slyder's Avatar
slyder
when installing the new carpet which goes in first. The rear section then the front lays over the rear under the front seats.
I thought this was right just wondering. Also is gluing the carpet down a good idea as in a post above his carpet slide around.
I'm at the point of installing the carpet. I just removed all the seats except drivers, had to still move car. Removed seat belts
and installed the new shifter boot after reseaming all the seams. I dry fit the underlayment and it looks good I was just
wondering about the 2 points listed above.
Thanks,
Slyder
Old May 21, 2006 | 01:48 AM
351foxstang's Avatar
351foxstang
ORIGINAL: Soaring
Give these members a call to help you. I bet they could have it out in a nano second.
carpet? thats easy stuff. we pulled the straight six without an engine hoist. [sm=yikesomg.gif]
Old May 21, 2006 | 02:02 AM
6mustang6's Avatar
6mustang6
quote:
ORIGINAL: Soaring
Yeah, me and my friend Gerald wrestling a V8 into a truck. We're not too small ourselves. Im 5 11 250 lbs. and he is the same almost.
Old May 21, 2006 | 05:04 AM
66ckurt's Avatar
66ckurt
i got a question how did you get you center console out when i got the bolts off and wires unhooked i found that flat peace of metal about 4 inchs wide 2 inchs tall prevents me front pulling the console out. how'd you get are that?
Old May 21, 2006 | 11:40 AM
Clu7ch's Avatar
Clu7ch
ORIGINAL: slyder
Thanks,
Slyder
well, when i pulled mine out, it came out back first than front section. lay the front section in and that fit the back over it. reinstall the mouldings and deats and it should sit fine without sliding around too much. basically the front won't go anywhere cause of the door mouldings and seats bolt thru the front section (and i believe the front facing end of the rear section).
jwog666
Dec 27, 2021 08:09 PM
b8checker
Oct 8, 2015 12:55 PM
Dathan
Oct 5, 2015 05:52 AM
jrrhd73must
Oct 2, 2015 09:17 PM
b8checker
Sep 30, 2015 07:11 AM
