throttle return spring
Old Apr 23, 2006 | 11:52 PM
popper's Avatar
popper
Default throttle return spring
Somebody please tell (or show) me where the little spring goes that holds my throttle closed. I think I might have the big spring right... holding the trans kickdown rod forward.
[IMG]local://upfiles/30705/BB547F13B63A467E9437B4CD9496865D.jpg[/IMG]
Old Apr 24, 2006 | 04:09 AM
mufftasticmonko's Avatar
mufftasticmonko
Default RE: throttle return spring
Looks like the kickdown is in the right place, the throttle however should pull the bottom forward (or top back). If you can get a throttle return spring kit from an autoparts store with spectre products there will be 2 springs in the kit, if you would like you can also get a return bracket from the spectre isle too. The bracket will bolt onto your intake front or behind the carb. In your case in front would be the better idea. Hope that helped!!!
mungodrums
Sep 28, 2015 10:54 PM
TfcCDR
Sep 14, 2015 12:08 PM
Sep 8, 2015 11:50 AM
zanemoseley
Sep 6, 2015 12:58 PM
