Compression Test
Old Apr 24, 2006 | 08:17 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Compression Test
You can have everything hooked up but the plugs, which have to be taken out.
Old Apr 24, 2006 | 08:22 PM
67Sally's Avatar
67Sally
ORIGINAL: Soaring
Yeah but I DONT have everything hooked up. However it did say that the car needs to be running with a good amount of air (should have gotten the clue from the name COMPRESSION but that's okay) moving throughout the engine. I guess that means that I gotta get the air cleaner on and postpone removing the carb
Old Apr 24, 2006 | 08:36 PM
Soaring's Avatar
Soaring
I ♥ Acer
I forgot about this. Disable the ignition module or coil. But that is not totally necessary if you have the plug wires disconnected, and the plugs out.
baddog671
Jul 26, 2016 01:20 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
GT350 S550 Tech
Sep 29, 2015 03:29 PM
